Old 03-08-2013, 12:00 AM   #31
Suspended
Novak Ballistic with the new HT rotor (#5955) and ceramic Bearings gets my vote....
bertrandsv87 is offline   Reply With Quote
Old 03-08-2013, 12:02 AM   #32
Suspended
Just remember to use Acetone to loosen the CA glue holding the steel Bearings in place before trying to take them out + some heat....lol...
Old 03-10-2013, 03:33 PM   #33
gom
So after looking more into the specs of each of the motor you guys suggested on this thread so far, I have come down to a few motor choices here between the Reedy, Tekin Gen2, Revtech, Thunder Power, and the Team Powers Plutonium.
However, I have notice the KV ratings on some of these motors are way higher than the average (that being 2300-2400 kv for 17.5). For example, the Tekin Gen2(high torque version) is 2400kv, Reedy Sonic is 2303kv, and Team Powers Plutonium is 2400kv. Speed Passion MMM 17.5 is at 2900 KV. And then we have the Revtech Maxzilla at 3300kv!!!
I am really bad at the electrical part of the hobby. I thought 3300kv ratings are supposed to be in the 13.5 turn range. My understanding is a 3000+KV rating motor will have much higher rpm than a 2400KV motor. How can some of these motor have much higher KV ratings and still be within the same league as the rest of the 17.5's (namely the Revtech Maxzilla)? I know I must be missing something here.
Yokomo BD5 - Yokomo BD7 - Futaba - Hobbywing - Reedy - Savox
gom is offline   Reply With Quote
Old 03-10-2013, 05:10 PM   #34
geeunit1014's Avatar
There is no standard way to measure KV. Its about as useful as measuring the size of the steering wheel on a car to determine what the top speed will be.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 03-10-2013, 07:16 PM   #35
Suspended
Kv is very misleading. Watts and torque are more important....
Old 03-11-2013, 12:37 PM   #36
Trader Rating: 17 (100%+)
Send a message via AIM to DJGonzo69
Revtec with HT rotor.
|XRAY|RCAmerica|Hobbywing|KO PROPO|Team Scream Motors|Gonzo PaintWorX|
DJGonzo69 is offline   Reply With Quote
Old 03-11-2013, 01:01 PM   #37
Trader Rating: 27 (100%+)
Revtech with high torque. I gear mine at 4.02 and use 2 ticks from full timing. Has tons of torque and my top speed is excellent. I also race on a small/medium sized carpet track. Motor comes off the track after 6-8 minutes at 135f.
hyujmn is offline   Reply With Quote
Old 03-11-2013, 03:09 PM   #38
gom
Thanks. I'll ignore the KV ratings then.
I've only been in this hobby for a couple years. But I am shocked at the amount of numbers and ratings that are meaningless in this hobby. C ratings in batteries for example is one of them. All these numbers are really confusing the hell out of beginners like me.
Old 03-11-2013, 03:12 PM   #39
gom
The Revtech is mentioned in more than half the responses. Looks like I'll have to give this thing a try.
Old 03-11-2013, 04:46 PM   #40
Team Tekin
Tekin Prez's Avatar
kv is a meaningful number really. It is how we rate 4 pole motors and is reasonably accurate because the kv is not effected much by timing. However 2pole motor are effected a lot by timing. Most of us rate them with low timing. Some rate them with the timing cranked up high. With the timing set the same they are all pretty close on kv.
Smaller dia. rotor gives you more kv (rpm) also, but at the expense of torque.
[email protected]
Smarter, Smaller, Faster....
www.teamtekin.com
Tekin Prez is offline   Reply With Quote
Old 03-11-2013, 06:51 PM   #41
Josh-n-ya's Avatar
Trader Rating: 75 (100%+)
Order from Trinity direct! Then you wont have to buy rotor seperately.
Josh-n-ya is offline   Reply With Quote
Old 03-11-2013, 10:47 PM   #42
Why is the c rating on a battery meaningless?
Always thought the higher C rating the better
JOE SI is offline   Reply With Quote
Old 03-11-2013, 10:54 PM   #43
Suspended
It is meaningless because there is no standardized way to measure it, one companies 100C is another companies 50C while yet another company will call it a gazillion C. And they are each using their own proprietary imaginary way to measure it.
RogerDaShrubber is offline   Reply With Quote
Old 03-11-2013, 11:43 PM   #44
Josh-n-ya's Avatar
Is that like measuring 20 guage motor wire!
Old 03-12-2013, 08:25 AM   #45
Trader Rating: 41 (100%+)
I love my Reedy 17.5 Just have to keep it clean. I run mine @ 35 degrees on the can and start at 4.5 FDR and test gearing from there. With the Reedy you need not worry about top speed just gear for how the car works in the Infield.
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
