World gt motor advice
I am looking to buy a 13.5 motor for my world gt car running 1s lipo. Now i can go with the normal d3.5 13.5 or other normal motors, but i see speed passion makes motors for 1s applications. Now should i go with a motor made for 1s like the speed passion or just stick with the normal motors like tekin and trinity.
I'm currently running a d3.5 with the 12.5 high torque rotor. I have run it with the standard 12.3 broad powerband rotor as well. Both combinations are quite quick, but I was able to gear up slightly and turn the timing down a bit with the bigger rotor. The car also seems to carry the laptimes deeper into rhe run with the HT rotor. I did add a little "roll" to the car to overcome the drag brake effect.
The Reedy and Thunderpower motors also run quite well.
I've been using an Express D3.5 with the torque rotor in WGT and 13.5 1/12. Both around a 85mm roll out and 23* on the timing. They both are always on pace and finish very strong, around .2 drop off at the end of a run. Reedy and Revtech were always .3-.4 slower at the end of a run.
