Old 03-05-2013, 10:17 AM   #1
Default Shock building
I've followed so many different ways to build shocks and I'm still having trouble getting the bladder to stay flat while screwing the cap on..
If I close the cap and the bladder moves will it let air in and intern have to redo the shock?
I'm trying to build with as little rebound as possible, any suggestions are greatly appreciated
JOE SI is offline   Reply With Quote
Old 03-05-2013, 10:48 AM   #2
R3VoLuTiOn's Avatar
Trader Rating: 27 (100%+)
After the oil has settled, push the piston 80% up, put the bladder on slowly, bleeding out excess air and oil, place the black plastic shock top on the bladder, then the shock cap. While threading the cap on, have one finger pushing down on the shock top to keep the bladder from moving.
That's the simplest way I've known to build em.
Would love to read more about others methods
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 03-05-2013, 10:56 AM   #3
Kwikvdub's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Kwikvdub
Thumbs up
Learn from the pros: http://www.youtube.com/watch?v=sliCxsIZ3v4
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 03-05-2013, 11:26 AM   #4
The easiest way I've found is to get the air out, then place the bladder on top. Once you've done this, push the shock shaft up and with a 1.5mm driver gently draw a circle in the bladder so it sits down (allowing excess oil out). When you're happy, pull the shock shaft all the way down and screw the cap on. This will ensure the bladder stays seated as you put the cap on.
This method takes about ten minutes to build a set of 4.
CPD Racing
chris_dono is offline   Reply With Quote
Old 03-05-2013, 11:41 AM   #5
But even when I do get the bladder seated perfect it always sounds like there's air in the shock when I compress it..
Could it be that there was a hole drilled in the shock cap to ensure no rebound and even if there's air in them eventually it'll be gone because of the hole
Old 03-05-2013, 11:42 AM   #6
Originally Posted by Kwikvdub View Post
I've learned from every pro on YouTube lol
Just always sounds like there's air in them
Old 03-05-2013, 12:21 PM   #7
Mr RCTech's Avatar
That shock tool from Tamiya works AWESOME!
Gets all the air out fast!
Mr RCTech is offline   Reply With Quote
Old 03-05-2013, 12:46 PM   #8
MikeXray's Avatar
Trader Rating: 73 (100%+)
What shocks are these, and you certain you have the right bladders? If a bladder is too big, or swollen, they cap can cause problems, but it really shouldn't if all is right.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 03-05-2013, 02:58 PM   #9
Top photon v2
I'm sure everything is right as far as the parts
I can get them where it feels like there's no air in them initially, but when I compress them it sounds like air is coming out of the hole that was drilled in the cap
Old 03-05-2013, 03:15 PM   #10
sosidge's Avatar
Top photon v2
You would expect air to come out of the hole in the cap - that's why the hole was drilled in the first place.
Old 03-05-2013, 03:44 PM   #11
Ok that's what I thought
And the answer I was waiting for thanks sosidge
