question about 19t
question about 19t
i have been running stock all my one road life which hasent been long but i am going to start running some 19t. i got two 19t motors, epic 19t outlaw (d6 can motor) and the reedy quad. both motors have been just cut and tuned with new brushes. however, when i dyno them on my orion motor dyno the numbers are much less then that of my stock motors. i dyno all my motors at 4V and i usually get around 11 amps and 10,000 rpm from my stocks but the 19t motors are only pulling 6.67amps with 8,500 rpm. did i get bad motors or do 19t motors just dyno that way?
Suspended
the 19t have bearings so no load they will have less amps being drawn. it means nothing for no load amp draw. just run them and see. most 19t have alot of tourqe and not much rpm ala the reedy. not shure about the trinity
The only way true way to test a motor is on the track
