Old 02-27-2013, 06:52 PM   #1
Default Kimbough gears for F1's
I need some help with gearing on my Tamiya F103. I have searched but can't seem to find my answer. I have a Novak GTB2 ESC and Novak SS 17.5 I plan to run on 2S. What Kimbough Gears will fit on the F103. Should I use 48 pitch or 64 and which Spur and Pinion should I use for best ratio for parkinglot running?
SANTAVY1 is offline   Reply With Quote
Old 02-27-2013, 07:32 PM   #2
If you get the Tamiya spur gear adapter you can run any standard spur gear.
Old 02-27-2013, 09:20 PM   #3
MarkerInbound's Avatar
Send a message via Yahoo to MarkerInbound
Has anyone noticed a difference with taking out the Tamiya spur with bearing and swapping it out for another spur and the spacer? I sure like the idea of having the bearing in/on the spur.
MarkerInbound is offline   Reply With Quote
Old 02-28-2013, 12:21 AM   #4
Odin544's Avatar
Trader Rating: 93 (100%+)
Yes. The more balls you have the better I liked the CRC spurs with 16 balls. Mucho smooth diff if you know how to build one.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 02-28-2013, 05:32 AM   #5
Where might I find the adapter and will this allow me to use kimbough gears?
Old 02-28-2013, 11:36 AM   #6
Search or Tamiya part number 54215.
RCMart TQ Racing TamiyaUSA
terry.sc is offline   Reply With Quote
Old 02-28-2013, 04:05 PM   #7
Cool, Thank you for link.
