Old 04-29-2005, 09:01 PM   #1
Ducati-Rider's Avatar
Suggestions for pinion gear on 27Tstk 64p TC4
Guys
I've picked up a BMI TC4 to run in onroad asphalt 27Turn
stock, rubber tires - 50' straight, tight outdoor, medium
bite track.
Where would you start with pinion gearing for a Epic
Binary stock motor - 64p,?
BTW - with a TC3 monster stock - I run 25-27 tooth pinion
on a 48 pitch gearing.
Your suggestions?
bill in ca
Ducati-Rider is offline   Reply With Quote
Old 04-29-2005, 09:03 PM   #2
NVisible's Avatar
how many teeth are on your spurs?
i would try to run what you did on your 48P setup (ratio)
www.gearchart.com can help you there
NVisible is offline   Reply With Quote
Old 04-29-2005, 09:07 PM   #3
big track the four mag is not the way to go...the monster is your best bet....the power band is really small on the binary
lickrim is offline   Reply With Quote
Old 04-29-2005, 09:09 PM   #4
Default thanks
It's hard to beat a monster for an all around motor IMHO
Old 04-29-2005, 09:10 PM   #5
scoobydo's Avatar
I agree. Find out what worked for you in 48p and get the drive ratio and rollout from that.
Then just try to come as close as you can with the 64p.
scoobydo is offline   Reply With Quote
Old 04-30-2005, 03:36 AM   #6
raving-monkey's Avatar
Send a message via MSN to raving-monkey
monsters are generally torquey motors, quad mags have quite a bit more rpm....so why would you be using a torquey motor on a large track where you would need more rpm?
raving-monkey is offline   Reply With Quote
Old 04-30-2005, 03:47 AM   #7
FYI, powerband is not really a term that applies to electric motors since they can generate power at ANY RPM depending on the load.
Peak torque to RPM ratio is a much better method of determining the better motor for a particular track.
Goonish is offline   Reply With Quote
Old 05-02-2005, 11:19 AM   #8
edseb's Avatar
Monster stock pro should be geared to be about 7.0 on final ratio with gp3300s and rubber tires. Just spur / pinion x internal ratio = gear ratio. Go up or down from there depending on track, but that should be good for 90% of tracks.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 05-02-2005, 11:50 AM   #9
kt racing's Avatar
Send a message via AIM to kt racing
Default Re: Suggestions for pinion gear on 27Tstk 64p TC4
Originally posted by Ducati-Rider
Guys
bite track.
Your suggestions?
bill in ca
Bill
Try a 100t 64 pitch spur and a 35 tooth pinion that should be a good starting point.
Your final drive ratio will be a 7.14 with this gear combo
Your roll out will be a 27.7.
So that should be pretty close. You will have to test a little bit more to see what works. Try not to get the motor too hot. Nothing over 190 degrees. Also a motor will run hot when it is undergeared as well.
Hope that helps
Keith
kt racing is offline   Reply With Quote
What pinion gear? agressive1 Micro and Mini Scales 3 08-01-2008 12:21 PM
Help super gear and pinion gear jojo RRR Electric On-Road 0 06-18-2007 07:37 PM
Would switching from a 19t pinion gear to a 21t pinion make a big difference ? thahookup Rookie Zone 5 05-19-2006 01:09 PM
Got an Xray. Now, what? (pinion/spur combination/tire suggestions) Tom G Electric On-Road 8 06-12-2004 05:04 AM
pinion gear yrless Electric Off-Road 1 03-23-2003 05:46 AM
