Old 04-29-2005, 01:52 AM   #1
Send a message via AIM to kid skid Send a message via Yahoo to kid skid
Default is am radio going obsolete?
hi. we all know the difference between an am and an fm radio. but what i want to "read" from you guys is..... AM going obsolete?
if il be racing, will am be of no use nowadays or in the future? if il buy an am radio now, consider a jr xr2i, how long will i be "holding" onto it. needing spome insights guys.. m no expert but m very willing to learn. tnx.
kid skid is offline   Reply With Quote
Old 04-29-2005, 02:10 AM   #2
Default Re: is am radio going obsolete?
as long as they keep making rtr kits to suit the beginner, i dought this would happen within the immediate future. sure fm is a better system but not everybody can afford it. plus most of the fm radio's can be quite confusing to the beginner. having said this though fm radio's for competition is the way to go.
flysti is offline   Reply With Quote
Old 04-29-2005, 06:18 AM   #3
ddesros2's Avatar
An entry level FM radio is not that much more than an AM radio. From experience, spend the money on a decent radio first (it will save you money in the long run). The only feature you really want to look for is the number of model memory it has (3 to 10 is good). If it has model memory it will have all the features you will eventually need if you start racing (even if you don't know what they all do yet).
A JR XR3i would be your best choice, it's about 130 to 140 and it has everything you need.
ddesros2 is offline   Reply With Quote
Old 04-29-2005, 07:08 AM   #4
Airtronics makes a MX-3A which is am also .
stumper is offline   Reply With Quote
Old 04-29-2005, 08:00 AM   #5
AM has been obsolete for years.
MartynD is offline   Reply With Quote
Old 04-29-2005, 11:03 AM   #6
Fran's Avatar
Trader Rating: 157 (100%+)
I second that.. just like am radio stations
Roadrunnersrc.com
Team Associated 12R5.2
Team Associated TC6.2
Team Associated TC7.1
Team Associated F6
Fran is online now   Reply With Quote
Old 04-29-2005, 11:27 AM   #7
EricF's Avatar
AM (from what I've heard) is actually a cleaner freq. I've been to tracks where FM radios will glitch but AM will not.
Never experienced this first hand, but i've seen it and been told that by others.
E
So I'd say no.
EricF is offline   Reply With Quote
Old 04-29-2005, 12:39 PM   #8
NVisible's Avatar
ive heard that as well... from a radio DJ.
which is strange because all the AM stations sound like crap compared to FM
NVisible is offline   Reply With Quote
Old 04-29-2005, 12:41 PM   #9
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
AM radio is more easily glitched. AM radio waves bounce off of things more easily and that is one reason why AM radio usually travels farther. When it bounces, the signal can degrade somewhat. FM is basically line of sight, with a higher quality signal. I am leaving out some stuff, and I am no expert, but I have seen basic explanations showing AM bouncing off of clouds etc in order to extend the range of the transmission whereas FM just stops.
Either way, don't buy an AM radio.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 04-29-2005, 12:44 PM   #10
RCGaryK's Avatar
AM (amplitude modulation) relies on the height of the wave to set the frequency, while FM (Frequency Modulation) varies the frequency by chanching the number of "Peaks and Valleys" between each wave length. Because of this, there's a larger gap for there to be interference in FM. At least that's what I remember from my electronics courses while staring at oscilloscopes...
If you buy cheap, you buy twice and end up spending 3 times the money. If you can afford a couple extra bucks, definately go FM. You can get a good computer radio from HiTec, the SRX, for around $100 with 10 model memory!
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 04-29-2005, 08:22 PM   #11
Send a message via AIM to greencactus3
Post
i think am goes through walls but fm doesnt? personally i use am and not so much trouble. unless im really close to a high power transmitter of another fellow racer. id upgrade, whenever i have the spare money.
greencactus3 is offline   Reply With Quote
Old 04-29-2005, 08:53 PM   #12
nimble's Avatar
AM is Amplitude Modulation, where the signal varies its strength to encode information, FM is Frequency Modulation where the frequency is varied to encode information. Because the signal strength can be effected by many things, it makes AM have a lot more noise.
The high-output power FM R/C radios can really effect AM systems.
Broadcast AM Radio goes farther than FM because it operates at a lower frequency, i.e. 1140KHz (1.14Mhz) verses FM Radio at say 98.6Mhz.
For R/C Radios, both AM and FM operate at the same frequency, 75Mhz, and basically I would say nobody uses AM for racing because it glitches in the presence of FM radios.
The good news, just to get a commercial plug in, is that we have a 2.4Ghz Upgrade kit for AM radios.
nimble is offline   Reply With Quote
Old 04-29-2005, 08:55 PM   #13
ChadCapece's Avatar
Don't buy an AM radio. But if your RTR comes with a computer style AM, then there is no need to upgrade right away.
Logically, FM would be a more clear signal since most musical stations use FM, and the talk shows use AM b/c the clarity is not as neccessary. And I you can listen to stations on AM that are much further away than FM stations.
ChadCapece is offline   Reply With Quote
Old 04-29-2005, 09:51 PM   #14
yo guys thanks a lot. hope you wont ever get tired sharing what you know.
2 DTX ICE - Car stands, 8000 7.4 lipos, B4 Spares, Tires, 3PK radio M8 radio spektrum racer34v R/C Items: For Sale/Trade 7 07-16-2008 06:10 AM
gt2 truck,spectrum radio,ae radio,glow starters.......trade for non rc realted xsxracing Other Items: For Sale/Trade or Wanted to Buy 1 08-07-2007 05:43 PM
gt2 truck,nitro extras,spetrum radio,ae radio,charger,battery more....cheap xsxracing R/C Items: For Sale/Trade 0 08-07-2007 08:40 AM
Good radio:fm, any brand, no offer refused! needed radio(3 channel t to the maxx2 R/C Items: Wanted to Buy 16 02-05-2005 11:20 AM
