Old 05-12-2005, 05:03 AM   #76
stjerno's Avatar
Originally posted by JDM_DOHC_SiR
THe ALEX Version will have the following colors.
BLACK
BLUE
RED
PURPLE
PINK
THe PAL version should be...
Satin Silver..and Possibly a new Color...
-Dave
Dave, do you know of any reason the price of the stinger is set at 55K yen ? (rather much for a stock TC)..
Is it made out of an - yet to be found, secrect compound that makes it win every race ?
stjerno is offline   Reply With Quote
Old 05-12-2005, 05:19 AM   #77
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
I know for one thing that ALEX will not be using the straight carbon with the stinger...and 55000 is not too bacd of a List price..since the 2005spec Pro4 lists for 57500
anyways you shouldn`t need too much from what I have been told..also the Stinger layout looks very similar to the IRS TC3 chassis
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽµ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 05-12-2005, 06:29 AM   #78
Herminator's Avatar
Send a message via ICQ to Herminator
Hmm, I was hoping they'd change the bevel input gears slightly, the little ears to hold it in place are just too much hassle. I'd rather have a small grub screw which would mean you could remove the bevel gear from the bearings without damaging it, most of the time it requires a new one.
So will the PAL version be even more expensive? I hope they include atleast some titanium goodies, or the steel screws use a hex head instead of the cross head ones.
Herminator is offline   Reply With Quote
Old 05-12-2005, 08:46 AM   #79
OSherman's Avatar
pics of the shaft version are posted..
tickle me
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 05-12-2005, 09:03 AM   #80
berger's Avatar
R/C Tech Charter Subscriber
tickle me
Thanks for the link, pity it looks hideous imo.
berger is offline   Reply With Quote
Old 05-12-2005, 09:48 AM   #81
Thraex's Avatar
Look at those gearcases!!!!
Thijs van M[HPI/HB]
Thraex is offline   Reply With Quote
Old 05-12-2005, 09:52 AM   #82
seaball's Avatar
Send a message via Yahoo to seaball
Default alex schlonger
i've been watching with anticipation for this development. alex is usually pretty innovative. preliminary comments, which nobody asked for.,
pros:
- sealed drive
- vertical ballstuds at chassis
- precise/durable aluminum bulkheads
- hingepin style suspension, which is more adjustable (i actually liked the balls since you don't ever have to shim them for play)
cons:
- gay bumper (the mounting posts almost rub the shocks as it's not nearly extended enough).
- wide... extra wide chassis. (maybe the sanctioning bodies have planned a secret rule change that calls for a 7mm minimum ride height)
- chassis could have been moulded, or at least the rails could have been fastened to it without screws so as to minimize tweak caused by shear.
- questionable ackermann alignment. the tie rods are way angled and it will get worse through the steering throw as the knuckle travels forward. perhaps the belt version will lift the rack over the arms and translate it forward as well since the shaft will be... gone.
- two piece diff cases. they could have been one piece (cast maybe) and the bearings could have slid in from the top/bottom using plastic inserts to hold them in place while the bulks seal to the chassis. again to minimize the surfaces that could shear against each other. picture it... the input shafts slide out of the top and the diffs slide out of the bottom.
- where do the sway bars mount to the chassis?
- centershaft drive should use plasic blades on 'em, as the pins will eat aluminum for breakfast and you will be left with a nice divot and tons of backlash over time.
it's early, we'll see how it goes... and the secrets we can't see may be uncovered.
early one to ten? - three point five!
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 05-12-2005, 01:33 PM   #83
edseb's Avatar
IMO it's pretty ugly. Maybe it works okay, but it better work great, cause it is fugly.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 05-12-2005, 01:33 PM   #84
Herminator's Avatar
hmm, it isn't elegant
Lots of room for electronics but they could do with shaving a few mm off the width of the chassis.
They could make it quite a bit narrower if they make the side rails big enough and locate the alloy braces well enough so that the cells are slide in the side under the upper rail and possibly have the outer edge of the cell still under the rail a bit. May make how you connect the cells to the speedo a little limited but it could be done....
On the other side they'de have to do a similar thing to the Barracuda, make it so the servo needs trimming
The bumper looks temperary since they only finished making proto type.
Thought they weren't going to go with rack steering, I hope that changes, or they atleast give us more steering throw than the R3.
Seems to have an alloy/graphite backbone under the main shaft, I like that idea, would be nice if there are spaces to add lead weights for ballast.
Looks like an alloy diff at the rear, I wonder if that will make it into the production car.
Old 05-12-2005, 02:29 PM   #85
Gazza_D's Avatar
Send a message via Yahoo to Gazza_D
Got rid of my IRS TC3 as it was a second a lap slower than my R2!
Its early days, we'll have to wait and see if they can pull the rabbit out the hat with this one
Gazza_D is offline   Reply With Quote
Old 05-12-2005, 03:21 PM   #86
sbs
sbs's Avatar
If we can't get the one that we love , then we have to love the one we get
Soren B. Sorensen
Team-manager
Empty Pocket RC-Team
Serpent S411 / Powered by EPRCT Motor Management
sbs is offline   Reply With Quote
Old 05-12-2005, 04:03 PM   #87
If you don't like what you see... then wait for the PAL version ... I know it will look quite different .. plus it will be on a diet for the Bulkheads.. and possibly a bit narrower chassis
-Dave
Old 05-12-2005, 04:17 PM   #88
sbs
sbs's Avatar
-Dave
Pictures Dave ! pictures !
We can't wait !!!
We are like small boy's
Soren B. Sorensen
Team-manager
Old 05-12-2005, 05:11 PM   #89
Man thats a lot of Lovin' then
-Dave
Old 05-12-2005, 05:24 PM   #90
For pictures of the Stinger, visit:
http://www.realrc.net/modules.php?na...article&sid=73
Sam Forbes is offline   Reply With Quote
Alex Racing Stinger dhiracing.com R/C Items: For Sale/Trade 0 05-09-2006 03:19 AM
Alex Racing Stinger review?? ezzydizzy Electric On-Road 1 03-13-2006 10:17 AM
Wanted Alex Racing Stinger tim fry R/C Items: Wanted to Buy 0 01-12-2006 01:26 PM
Tamiya TB Evo3/4 vs. Alex Racing Barracuda/Stinger vs. AE TC3/TC4 vs. HPI Pro4/2005 Nicadrauspro4 Electric On-Road 1 10-28-2005 05:29 AM
44.Shizuoka Hobby Show (TA-05, Alex Stinger, TT-01R, ABC Hobby Genetto etc) chaini Electric On-Road 2 05-13-2005 02:59 AM
