Old 08-15-2005, 01:54 AM   #361
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally Posted by stjerno
Nice..
Like the idea of having 3.2mm front tower.. was a little weak on the Cuda.
How thick is the buttom and "top" plate ?
-Claus
Bottom deck is 2.4mm
Top Deck 3mm
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 08-15-2005, 02:58 AM   #362
stjerno's Avatar
Talking
Top Deck 3mm
-Dave
Any news on the PAL version ?
How much is going to be diff ... and is it gonna be a new car or just hopup parts ?
Is PAL going to make a thicker bottom (thinking carpet here ) ?
Claus
stjerno is offline   Reply With Quote
Old 08-15-2005, 04:13 AM   #363
Fatboy Joe's Avatar
JDM_DOHC_SiRWhat parts from the R2 that can be used on the stinger? Just curious. Thanks
Fatboy Joe is offline   Reply With Quote
Old 08-15-2005, 04:44 AM   #364
Bevel gears front and Rear
Springs
Front dogbones
Shocks..
and thats about it..the Stinger is pretty much a new car
-Dave
Old 08-15-2005, 05:08 AM   #365
Claus
THe PAL version is still in the design stages..... I beleve that the PAL version will be a hopup...but there should be a limited kit version...
SO far from what I know is...
PAL carbon center shaft..(similar to team bomber shaft)
PAL Alloy rear diff
Light weight easy access diffs
Light weight carbon chassis... more than likely 3mm thick
-Dave
Old 08-15-2005, 05:12 AM   #366
stjerno's Avatar
Dave-
Petter is trying to contact you !!
So they are already working on an improvement.. guess the driveshaft is only for stock racing but the bottom and the bulk heads .. would be nice with easy access for changing spurs.. (don't ever need access for diff gears.. they'll last for ever)
Claus
Old 08-15-2005, 05:29 AM   #367
Dave-
Claus
I just sent Peeter a PM..
THe PAL shaft will be able to hold mod motors no problem... it`s going to be different than the 1st line of R2 PAL shafts..and basicaly the pal diff cases with be for easy maint. and light weight plus..easy spur gear removal..so you will more than likely see a slight change in the motot mount
-Dave
Old 08-15-2005, 05:32 AM   #368
stjerno's Avatar
-Dave
Any ideas on a time frame ?
Claus
Old 08-15-2005, 05:44 AM   #369
Claus
November time frame for the PAL version...more than likely just before the Japan Nationals
-Dave
Old 08-15-2005, 06:15 AM   #370
@Dave
Can't find your PM in my inbox...
Please try my e-mail instead...
Petter Slvberg
Norway
PetterS is offline   Reply With Quote
Old 08-15-2005, 06:38 AM   #371
Originally Posted by PetterS
@Dave
Thats what I meant...sorry.. you have a E-mail Petter...
hit me back up tommorow and I`ll get back to you on that ..
-Dave
Old 08-15-2005, 06:48 AM   #372
stjerno's Avatar
-Dave
So Dave- you been at the track yet ?
How is the Stinger compared to the Cuda, TC4 and all the other cars you been driving lately ?
-Claus
Old 08-15-2005, 05:14 PM   #373
FaiLip's Avatar
-Claus
I want to know too, especially comparing to the BD, especially when Dave said that the Stinger handle pretty much like a belt drive.
FaiLip is offline   Reply With Quote
Old 08-16-2005, 01:14 AM   #374
Dave must be very busy playing with his new toy
dhiracing.com is offline   Reply With Quote
Old 08-16-2005, 01:29 AM   #375
I Had a good outing with the car again last night... Here is the set up that I have so far.... it's for med-high grip
Front
Oil 40
pistion 1.2mm
Spring Rayspeed White
Stabilizer 1.2mm
shock tower ..1 in from outside
sus arm inner hole
ride height 4.5mm
rebound 4mm
Sorex 36R
1 deg camber
.5 deg toe out
inner upper camber link with 1mm shim under ball stud
Team Bomber Red inner
Rear
Oil 35
pistion 1.2mm
Stabilizer 1mm
shock tower 1 hole in from outside
sus arm outer hole
ride height 4.8mm
rebound 5mm
Sorex 36R
2deg rear toe block
1.5 deg camber
inner upper camber link .3mm shim under ballstud
Ride Accord Version"2"... or Mazda 6...
This set up has very good corner speed and is very easy to drive... if you want a bit more aggresive turn in switch to the Mazda 6
also broke my 1st part after 22 packs today......
1 steering knuckle..... seemed to break in the same spot as the Barracuda did..... but I have a fix for the Stinger knuckles that I will post in a day or two....... .
-Dave
Alex Racing Stinger dhiracing.com R/C Items: For Sale/Trade 0 05-09-2006 03:19 AM
Alex Racing Stinger review?? ezzydizzy Electric On-Road 1 03-13-2006 10:17 AM
Wanted Alex Racing Stinger tim fry R/C Items: Wanted to Buy 0 01-12-2006 01:26 PM
Tamiya TB Evo3/4 vs. Alex Racing Barracuda/Stinger vs. AE TC3/TC4 vs. HPI Pro4/2005 Nicadrauspro4 Electric On-Road 1 10-28-2005 05:29 AM
44.Shizuoka Hobby Show (TA-05, Alex Stinger, TT-01R, ABC Hobby Genetto etc) chaini Electric On-Road 2 05-13-2005 02:59 AM
