Air Compressor PSI for Cleaning
So I am getting an air compressor to quicken the cleaning time of my TC and Buggy.
I know 150psi (which seems to be the max) can knock the dust off an ATV, but what is good enough for my TC? I saw a really inexpensive one that is rated at 40psi. I need something powerful enough to clean caked on dirt from my offroad. Is 40psi enough? Any of you guys got info or brands? |
I like using 75-100 psi on my electric TC. It works very well, and is not near the pressure needed to mess anything up. 40 is going to be too little; I guarantee it.
try it and see what works best... thats the only real way.. some comressors are diff then others..
Originally posted by burbs try it and see what works best... thats the only real way.. some comressors are diff then others.. However, is 100psi seems to work, I guess I will search for something in that range. |
ahhh.. most places where i live hve a demo model setup to try.. sorry ..
The one I have is 100-120 PSI and has a little handle so I can take it with me to the track.Got it at harbor freight for $90.
Originally posted by Hyper1 The one I have is 100-120 PSI and has a little handle so I can take it with me to the track.Got it at harbor freight for $90. |
It is a central pneumatics model # 90168
Check your local Wally-World. They carry a 2 gallon Campbell Hausfeld (good brand) that is perfect for RC use be it cleaning or airbrushing. Up to 100 PSI with built-in regulator, all for $69 back near the automotive department.
Edit: Meant to say that this unit is small, little blue and black one - built in handle and all, great for carrying around to tracks, etc - barely bigger than a toolbox. |
I had one of those and it lasted all of about two years and quit working, took it apart to see if I could fix it but the cylinder wall was so worn out that it was useless.The one I have now is the same size,just wanted to try a different brand to see if it lasted a little longer.
I just picked one up from Sears. It is the Craftman 3gal 150psi? I am using it for airbrushing, and cleaning. $100 on sale.
Originally posted by jw92656 I just picked one up from Sears. It is the Craftman 3gal 150psi? I am using it for airbrushing, and cleaning. $100 on sale. Originally posted by factoryteamryan Check your local Wally-World. I'm sure it's like a local hardware store right? It just sounds like Chevy Chase and John Candy should be working there!:lol: Thanks for the info guys. |
Are you talking about a portable to take to the track? or one you would use at home? no campbell hausfeld for me had several 7 they all leaked at some place some where no matter what i did, went to coleman got a 11 gallon upright, for home 125 psi & a 2 gallon 100 psi never a problem with either. the 11 gallon is around 130.00, & the little 2 gallon is about 40.00 at pep boys.
Its all in what you want to do with it. I have had a couple different 2 gal. units one being the camble housefield wich is an oil-less head design. good for air brushing due to being oil-less , but life span was less than a year using it almost every weekend.If you are using it for cleaning the cars buy the craftsman from sears..... It will cost you around $119.00 and they run sales on it for $99.00 . It is a oil lubricated head and they last forever (as long as you maintain the oil level) I would not recommend airbrushing with it unless you add a good quality air filter. It also has a regulator built in wich is adjustable to give you what ever pressure you want from 0 -150 psi.
STUDY
BACK IN THE 60'S THE MILITARY DID A SIDE BY SIDE STUDY OF TWO WORK SHOPS BOTH DOING THE SAME MACHINE WORK..
OVER A PERIOD OF A YEAR ONE SHOP USED A SIMPLE BRUSH TO CLEAN DEBRIS FROM THE MACHINES, THE OTHER USED COMPRESSED AIR THE SHOP THAT USED THE BRUSH HAD NO BREAK DOWNS, THE OTHER HAD MANY (bearings mostly) machines go to repair... what im saying is the air you think is cleaning your car is being forced into place (BEARINGS) AND OTHER PLACES THAT RUIN MOVING PARTS...THE BRUSH IS BEST ..OH YA THE SHOP WITH THE AIR WAS SHUT DOWN DO TO MUCH REPAIR COSTS... 150 PSI INTO A SMALL BEARING YOULL GO RIGHT THROUGH THE OUTER SEAL....FOOD FOR THOUGHT |
