Old 02-20-2013, 12:54 AM   #1
Default xray t3 setup help needed
i have setup my xray t3 to the book and have now started to play with set ups.
i have used for example some of the carpet setups on the xray website for running on carpet.
the problem im having is when i set the droop to the say 6 on the front and 5 on the rear when i come to set my ride height the car is at around 7-8 with the shock collors all the way up so when i want set the ride height to say 5-5.5 i cant achive this.
any thoughts on this.
if it help i am running on an indoor carpet track which is now going to be less technical and more flowing and on rubbers if anyone has a good setup for this i would be much appreciated
andrewd is offline   Reply With Quote
Old 02-20-2013, 01:02 AM   #2
Where are you measuring at? Under the arms? What method are you using?
Minh Nguyen
[Maclan Racing] [Xpert Servos]
trigger is offline   Reply With Quote
Old 02-20-2013, 01:34 AM   #3
im using the huddy set upgages and measuring under the arm
Old 02-20-2013, 02:15 AM   #4
Trader Rating: 60 (100%+)
You should be measuring on the outside edge of the arm. As in not under the hub, but beside it where the arm extends out for the pin to go though.
PROMODVETTE is offline   Reply With Quote
