Old 12-02-2007, 10:53 AM   #1351
Default icc charger shuts down
hi
i got an icc charger that shuts down whwn im starting the charge ,
i dont get anything wrong under system checking when i starts the charger .
any ideas .
can i send it directly to spintec , i bought it at rc-mushroom a month back
tomin
tomin is offline   Reply With Quote
Old 12-02-2007, 11:18 AM   #1352
Victor Vector's Avatar
Originally Posted by prodriver View Post
Hi Guys, got a new spintc with 5 cell built into it. GGot some brand new smc4200's cells are 3 run old, they charge up to 3900 to 4100, got a ctx d2 discharger when doing the pulse discharge at 30amp.. the lowest cell in the pack is 409 seconds and the highest cell is 460???? discharging down to 0.9 per cell.
any ideas charger or cells just crap??
Ricky Copsey
CTX D2 is a dodgy toy in my book. I spent week figuring it out to be a very non scientific tool. Test same pack twice a day for 5 days. Never had numbers close to each other.
Jacko
Jack Balchin.
Timezone Hooligan
IBEW Local 48-retired (Definitely, great pension.)
Victor Vector is offline   Reply With Quote
Old 12-02-2007, 11:41 AM   #1353
Send a message via ICQ to rcnewb2004
Any news on when the next update will be? its been nearly 6 months!
rcnewb2004 is offline   Reply With Quote
Old 12-03-2007, 04:12 AM   #1354
radio_car_racer's Avatar
for info
here's a charge & discharge graphs of what the ICC is doing to your cells
charged @ 5 amps to 40c
discharged @ 10 amps to 0.9v per cell
spintec I.C.C charger-3700-pack-2-charge.jpg   spintec I.C.C charger-3700-pack-2-discharge.jpg
radio_car_racer is offline   Reply With Quote
Old 12-03-2007, 07:29 AM   #1355
Newb looking at the graph here (the first time to take a good look),
but I do notice something strange, it looks like not every cell is being cut off at the same voltage.... although the cut off is set at 0.9V. cell 4 cuts off earlier than cell 1 by a fair fraction of a volt. (I am assuming the quick dip in voltage together with the sharp rise is an indication of the cell dumping).
The drop in voltage of the cell 3 and 4 also have a much sharper drop, (an indicator of a good cell?) vs, something like cell 1.
Also curious, what are you using to make these graphs, they look cool, but wish there was something on that x-axis
Old 12-03-2007, 10:26 AM   #1356
yokemad's Avatar
ICC + BATMAN is the best battery treatment out there on the market...
That is so sad to see there is still no LIpo charging yet because of that reason I am start thinking about the sell that State of the art charger+discharger units
yokemad is offline   Reply With Quote
Old 12-03-2007, 10:52 AM   #1357
in reply to renewb2004,
good spot
I just uploaded the image without looking @ them
have emailed Spintec to ask if they can shed some light on that
sharp rise in volatge is were the 10amp load is removed from the battery
can't say what I'm using but I guess someone will know. Nothing is recorded or hidden on the x-axis
cell data from the discharge is in the attachment
Old 12-03-2007, 04:58 PM   #1358
Angry cel 1 is not working well
bought my Spintec charger second hand. At first it worked well but today I started to charge a 5 pack en suddenly the voltage in cel 1 started to drop. No connection problems or overheating. So I tryed another pack. Same problem. Anyone with the same problem? I seem to start afther a charge of 60 mAmp. All the other cell's are fine, It is just cel 1.
pevr is offline   Reply With Quote
Old 12-03-2007, 08:14 PM   #1359
KoE
KoE's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to KoE
Yo!
KoE is offline   Reply With Quote
Old 12-04-2007, 06:20 AM   #1360
Guys
Due to get my ICC in the next few days and cant wait, what settings should I use for amp charge rate, delta cutoff and temp for the follwing
IB4200
gp4300
gp3700
gp3300
Im a real newb with this charger also where can I get the USB cable for? is it worth getting it? and will I notice more power from my packs????
gaza121 is offline   Reply With Quote
Old 12-04-2007, 07:40 AM   #1361
you will notice your old packs last longer, they seem like "new" longer. cable is worth getting, those updates are important to the charger and your investment in general.
Old 12-04-2007, 04:49 PM   #1362
yokemad's Avatar
@Gaza
there are some ready setups in charger for different type of cells
First try factory settings
Old 12-05-2007, 04:24 AM   #1363
Has anyone measured the Amps the charger is really putting on the External output?
Yesterday I set it up for 2A, measured with a Multimeter I got a reading of 8.5A!
I tried it several times but all it gave was 8.5A...
2nd question, I cycled my 4 cell packs yesterday and cell 4's voltage is floating... measured on the clamps: 1.35V, charges indicates something varuing from 0.7->1.1V.
the strange thing is, when I put in a 6 cell pack readings are perfect! Also for cell 4.
Just got it back from repairs and I dont feel like sending it in again if anyone knows the failure, please tell me and I'll see if I will do the repairs myself.
(oh yeah, using soft version 1.07b)
Make it idiot-proof, and someone will make a better idiot.
Quante is offline   Reply With Quote
Old 12-05-2007, 06:30 AM   #1364
The external output is garbage. basically, don't use it for anything, but maybe to power a lathe.
Check your contacts... clean the surface of ur bars with rubbing alcohol, it may give better numbers
Ta04-TRF, EVO 5
Futaba
KO Propo
Spintec
Old 12-06-2007, 03:07 PM   #1365
This may have already been covered but I couldn't find anything on it. Why does my charger only let you charge at 6 amps since the latest update??? All the Doc's say 10 Amp max. What gives?
Jack
jackh is offline   Reply With Quote
Spintec ICC Charger MDawson R/C Items: For Sale/Trade 1 01-29-2008 09:05 AM
Spintec ICC charger ioxqq R/C Items: For Sale/Trade 2 07-15-2007 10:53 AM
Spintec ICC charger Dusty Kemp R/C Items: For Sale/Trade 1 10-27-2006 06:33 AM
Spintec Charger Nuno Gancho Electric On-Road 3 07-21-2006 04:32 AM
