spintec I.C.C charger >
Old 07-17-2007, 05:30 PM
  #1261
yokemad's Avatar
@Tel
That's what I am exactly doing
@Bill
Agree with spring stuff That is dummiest ever idea
Price Is ofcourse High but Idea really good covers the price....
yokemad is offline
Old 07-17-2007, 08:13 PM
  #1262
The new ICC (hardware version 1.5, black faceplate) has improved, stronger spring design. On our local track couple of guys use it for some time now, not yet seen one with a problem. I agree the fan could be a bit bigger in it.
aston is offline
Old 07-17-2007, 08:18 PM
  #1263
billjacobs's Avatar
Trader Rating: 61 (100%+)
Default new design
That's great for the new owners who forked over $400. What about the owners of the original design where the springs were soldered onto the board? (by the way, the best way to fix it in the design was to use a nut and bolt through the board and run a jumper to the contact point in the circuit.)
Again, great idea, very poorly executed.
billjacobs is offline
Old 07-18-2007, 01:01 AM
  #1264
I found that if you do not give the springs any downwards force, they then to stay in place... as soon as the springs are pushed downwards the solder joints will break.
rcnewb2004 is offline
Old 07-18-2007, 02:36 AM
  #1265
I was thinking about getting one of these but am unsure about a couple of things.
I currently have a Trinity DPD and have heard that the cell connections are the opposite way round for the Spintec to other manuafacturuers, is this right?
Logically the cells could be flipped over if this is the case (rather than changing the config) but i mount the corallys on top of the cells rather than on the side - would this stop it fitting into the Spintec?
Are there any alternatives from the Spintec that do individual cell charging?
stuartb is offline
Old 07-18-2007, 05:12 AM
  #1266
Trader Rating: 22 (100%+)
Originally Posted by rcnewb2004 View Post
I have read that good temp readings on the upgraded software from spintec only come when fans are ontop of the batteries.Then the charger will cut off more accurately.
Have you guys gave that a try?
I have been using the first version of the muchmore battery heatsink turned upside down. Three 40mm fans.
It dosent blow directly on the cells it draws the heat away.
As for peak settings I use .3 to .5 mv settings wih a pek temp setting of 55 degress celsius, and still put upto 5200mah plus in the packs
Had one pack go to 5650mah got someone to verify as I thought my eyes were not working.
bjspinner is offline
Old 07-18-2007, 03:59 PM
  #1267
stuey's Avatar
can you turn the temp setting off on the icc or do you just turn it up and hope the cells peak off first.
stuey is offline
Old 07-18-2007, 04:51 PM
  #1268
Skiddins's Avatar
Have you tried v1.07 software?
Also, try discharging the pack after it puts that in and see what the pack actually contains.
Skiddins
Skiddins is offline
Old 07-18-2007, 06:16 PM
  #1269
I set mine to peak at 56 degrees (but in reality, its actually about 50 degrees or so).... on version 1.07b. charging at 6A, i am still using old skoo gp 3300s, and peak setting at 2.8mv, this gives me pretty good results.
Old 08-03-2007, 11:45 AM
  #1270
MadBrushRacing's Avatar
Default Cell matching
Hi
Has anyone tried to rematch their packs on their Spintec? If so what figs did you use?
I did 1 cycle on all my EP4200 cells and used the discharge secs and mah to match against.
See below for figs
Before match After match
Discharge Discharge
Cell Pack secs mah Cell Pack secs mah
b 1 1283 3566 e 1 1407 3908
c 1 1326 3685 a 2 1396 3880
f 1 1350 3752 d 2 1416 3934
a 1 1365 3791 c 4 1421 3949
d 1 1375 3820 c 5 1436 3991
e 1 1407 3908 f 5 1427 3963
Ave 1351 3754 Ave 1417 3938
b 2 1295 3598 a 1 1365 3791
f 2 1347 3743 d 1 1375 3820
c 2 1348 3744 f 1 1350 3752
e 2 1369 3805 c 2 1348 3744
a 2 1396 3880 e 2 1369 3805
d 2 1416 3934 d 5 1375 3820
Ave 1361.83 3784 Ave 1364 3789
a 3 1243 3453 c 1 1326 3685
b 3 1278 3550 f 2 1347 3743
e 3 1283 3566 c 3 1340 3723
b 3 1289 3582 f 3 1336 3712
f 3 1336 3712 a 4 1316 3656
c 3 1340 3723 b 5 1348 3744
Ave 1294.83 3598 Ave 1336 3711
b 4 1262 3506 b 1 1283 3566
d 4 1272 3533 b 2 1295 3598
e 4 1303 3619 b 3 1289 3582
f 4 1314 3652 e 3 1283 3566
a 4 1316 3656 e 4 1303 3619
c 4 1421 3949 f 4 1314 3652
Ave 1314.67 3653 Ave 1295 3597
e 5 1210 3363 a 3 1243 3453
a 5 1258 3495 b 3 1278 3550
b 5 1348 3744 b 4 1262 3506
d 5 1375 3820 d 4 1272 3533
f 5 1427 3963 a 5 1258 3495
c 5 1436 3991 e 5 1210 3363
Ave 1342.33 3729 Ave 1254 3483
cell 1 = a
cell 2 = b
cell 3 = c
cell 4 = d
cell 5 = e
cell 6 = f
Any thoughts?
MadBrushRacing is offline
Old 08-05-2007, 08:40 AM
  #1271
Default SPINTEC ICC PROBLEMS
Only had charger a couple of weeks and have 2 problems.
1.Cells mostly thermal rather than peak 99% of the time.
settings.
a.charge rate 5.6 amps
b.temp 56c
3.cutoff 3 mv
charging 4 cell packs .
My biggest problem is odd cells peak long before they charged Have to stop charging and start again.
The cut out seems to be very sensitive and takes 3/4 charges to fully charge a pack,by then they have thermaled instead of peaking.Do i have a problem
tellan is offline
Old 08-05-2007, 05:39 PM
  #1272
yokemad's Avatar
@tellan
If you need upgrade to the latest software for better results
yokemad is offline
Old 08-06-2007, 04:20 AM
  #1273
settings.
b.temp 56c
3.cutoff 3 mv
You can try changing the cutoff to a lower setting I use .3mv and increase the temp cutoff voltage.
People will say cutoff temp higher but if you lower the mv setting the cells wont heat up as much at the end of charge.
I have no trouble with capacity due to low mv setting my packs ALWAYS have great power and runtime.
You may find that the packs you are charging are suspect, if they have been equalised before charge and they show signs of the inbalance between cells that you say this could be the case.
Dont worry to much about inbalance as one of the features of this charger is to charge each cell on its own, as long as the power is there and runtime all is good.
Imagine if you were using an ordinary charger and your cels were this much missmatched, one or more over charging some under charging?
Old 08-10-2007, 03:49 AM
  #1274
Thumbs down GRRRRRRRRRR
I purchased a second hand ICC charger with old firmware. I began to update to 1.07 with it freezing at the end.. after sitting for an hour or so I bit the bullet and turned it off and back on...... and.. the two lines and no text showed up.. I retried upload the firmware.. but on the 3 computers and 2 cables I tried it on.... they wont recognize the charger.. I noticed the plug was loose and I resoldered it.. NO SUCCESS... I paid good money for what I hope to be not a paperwait.. 3 days with no response to the email I sent Erik and [email protected]. Beginning to think I wasted my money.
Chad
:flam ing:
ChadL is offline
Old 08-10-2007, 06:58 AM
  #1275
SkeeryJones's Avatar
lots of faces in this thread.
is it really much benificial to charge independently? seems more headaches than benifit
SkeeryJones is offline
