spintec I.C.C charger >
Old 05-15-2007, 10:38 PM
  #1156
i ordered one on Ebay said it is new, but it wasn't. the unit powered on but can't charge with the internal tray. So i opened it up and found out the spring post circuit was broken, then i repaired the it and glue the post with CA on the board. Now it works.
second is a trinity dpd. it worked for a while, but it just can't discharge one day. i opened it and found out a broken solder join on the battery contact.
so double check it then.
tough guy is offline
Old 05-15-2007, 10:40 PM
  #1157
one more thing. alway keep it at close position, otherwise the tension eventually will create problem.
Old 05-16-2007, 02:16 AM
  #1158
Hi, someone knows something about new firmware?
unico2003 is offline
Old 05-16-2007, 02:24 AM
  #1159
Shop Owner
nnick's Avatar
I guess if there will be one we will find it from their site www.spintec.nl
nnick is offline
Old 05-16-2007, 07:52 AM
  #1160
There is some new firmware we are testing.
When it's totally done it will be on the spintec website, www.spintec.nl
Rob Janssen
Rob Janssen is offline
Old 05-16-2007, 04:14 PM
  #1161
Skiddins's Avatar
Originally Posted by krkisc
I picked up a spintec ICC on line, but I am having a small problem with getting contact on the number 1 cell. I keep getting an error message that I am missing contract on cell 1+. I have cleaned the contacts, moved the cell around and have made sure that the two contact wires are on the +button.
Ant help and or suggestions would be welcome.
Unscrew the bottom and check for the following;
The solder joints go eventually, and as has been mentioned, always leave the charger in the 'Closed' position.
Skiddins is offline
Old 05-22-2007, 05:47 AM
  #1162
djw
Default second service
guys, you do not know or do not care of repeaking?
Originally Posted by djw
Can anyone please describe what does exactly Repeak functionality mean? what if this is disabled? There is no single word on this in user guide.
djw is offline
Old 05-23-2007, 06:35 AM
  #1163
trf junkie's Avatar
Hi guys,
On the topic of auto repeak, has anyone actually seen this happen?.
I have the new version and did a pack last night, when it completed it charge and finished, I left it alone for about 15 minutes and felt like forever, but nothing happen, no repeak whatsoever.
Does this happen the same day, or year, any info will be appreciated.
thanks
trf junkie is offline
Old 05-23-2007, 07:42 AM
  #1164
It will only repeak when, for example, cell nr2 has peaked @4200mah and the other cells are still charging and are @4600. If cell nr2 is under a specific temp. (I think 40~45C) and has (not sure how much less) around 300mah less then the other cells, then the ICC will repeak cell nr2.
Stevenkoiter is offline
Old 05-24-2007, 08:11 AM
  #1165
Thanks for explication. I seen that during charge of a bad pack but I was not shure of procedure.
Ciao
Old 05-24-2007, 08:28 AM
  #1166
trf junkie's Avatar
Hi guys, I mailed Erik and got a reply, see below...
"What is does is detect a cell that might have peaked false (too early). If a cell cuts off, and it has accepted 200mAh less then other cells and temperature is below 38 degree C it will automatically restart charging that cell".
I have done a pack where certain cells took more than 500 mAh than others and no repeaking took place, so no I can not agree unless the temperature was above the set min allowed?...
I will try increasing the min temp cut off to about 45 deg celcius say since my packs are peaking at about 52 degrees. I noticed that its not quite calibrated correct, cross checked its about plus minus 5 degrees out say.
I'll post my findings.
Old 05-29-2007, 07:58 AM
  #1167
new versie 1.07 download
at www.spintec.nl
gizmo is offline
Old 05-29-2007, 08:48 AM
  #1168
trf junkie's Avatar
Does anybody know what has changed in the new software version 107?.
Old 05-29-2007, 08:55 AM
  #1169
mooony's Avatar
v1.07 beta - 29/05/2007
- cycle function
automatic charge/discharge for pack testing/cycling
- min/max capacity setting
use the max capacity for example to store your packs with 500mAh in it
use the min capacity for preventing false peaks
- lower min. temp and higher max.temp in charge settings
- cut-off system indication
this will tell you if the charging has been stopped by temperature, deltapeak or max cap setting
- bad-cell indicator
during charging you will see an X below the cell number to indicate that the cell might have a problem
- C.V.R. system (Cell Voltage Rebounce)
This system will tell you how the voltage bounces back after discharging. It will give you the cells voltage 1
and 2 minutes after discharge cut off. We feel this can be used to find broken cells. Its still experimental,
so any input on this is welcome.
- Improved system check (more reliable error messages)
- Fan setting
Auto: as usual, if temp of pack is above 32 degree C
On: fan will always be on
Check the Firmware_History. It has all the changes in it.
Ronald
mooony is offline
Old 05-29-2007, 09:03 AM
  #1170
trf junkie's Avatar
thanks Mooony/Ronald
I just went and there is no firmware history change as yet, but thanks for posting it!
Do you know if they will release a updated manual reflecting all these changes or is it user friendly, idiot proof
thanks, I will load tonight....
