Old 02-12-2007, 08:50 AM   #1081
Originally Posted by Erko
Hi, sorry if this question is old!
what's the difference between the different hardware version? How i can recognize it?
What's the difference between the "in wiew lever" (like the photo in official web site) and covered lever?
Sorry for my english
Erko, italian racer
The charger with the Newer Hardware has a different arm to open and close the battery bars and is inside the charger and not on the outside as with the older one.
Don't know what you mean with "lever" or something, sorry.
Rob Janssen
Rob Janssen is offline   Reply With Quote
Old 02-12-2007, 12:46 PM   #1082
Rob Janssen
ok thanks!
i have read this:
- 5 cell option added (note: this also requires hardware update kit for
hardwareversions 1.4 and lower!)
so i asked you...
Erko is offline   Reply With Quote
Old 02-12-2007, 09:41 PM   #1083
RC MARKET's Avatar
ok thanks!
i have read this:
so i asked you...
where to buy this 5 Cell option parts to add in ICC ?
RC MARKET is offline   Reply With Quote
Old 02-26-2007, 10:04 PM   #1084
1shnot's Avatar
seems like they are really busy.... what is the best way to get hold of one of them from spintec? one email has been exchanged, since then no news for few days.....
-Fast cats
-eXpress motorsports
-T.O.P
-Airtronics
1shnot is offline   Reply With Quote
Old 03-01-2007, 09:42 PM   #1085
Send a message via ICQ to rcnewb2004
I also need a icc cable, any online stores that sell the cable??
Ta04-TRF, EVO 5
Futaba
KO Propo
Spintec
rcnewb2004 is offline   Reply With Quote
Old 03-01-2007, 11:08 PM   #1086
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default ICC cable
I got my ICC cable a few weeks ago from HorizonHobby.com
Ordered it on a Monday and received on Thursday.
Took around 4 minutes to update the software, from breaking out of the package to hooking up the cables.
Temp readings are still off a bit but I ordered the Integy twin fan (21.00) setup from Horizon at the same time and the temp readings are pretty darn exact with the extra airflow.
The combo of the MuchMore CTX-D2 and the Spintec is absolutely awesome for full battery care.
I just wish i could charge my transmitter lipo pack on this beast so I could get rid of my Int16x8.
Come on Spintec hook us up with that option
olhipster1 is offline   Reply With Quote
Old 03-02-2007, 04:12 AM   #1087
can u show me ur icc setup olhipster1?
thanks... i will check if i can order from horizon hobby!
Ta04-TRF, EVO 5
Futaba
KO Propo
Spintec
Old 03-02-2007, 12:06 PM   #1088
olhipster1's Avatar
I only show my girl my ICC setup...
Autopeak = Yes
6 cell
temp = 118 F degrees
peak = .01 (i think going of memory) use the lowest possible setting
I use the step charge setup.. for 4200 cells.
5.2 amps - 1500mah
4.0 amps - 3200mah
6.0 amps - until finish.
i double up on the second phase because i don't think the spintec drops down the charge amp at one shot but gradually (just a hunch) that way it will cut down on overheating the batteries. this does depend on your battery condition. My batteries are pretty old but work great.
use a similar set for 3800's
Old 03-02-2007, 12:35 PM   #1089
i just wanted to know how u hook up the fans to the icc charger
hmm.. i am glad u also notice that... that the icc takes a while for it to lower its amerage... anyone try to lets say go from 6.0A --> 1.0A and see how long it takes this charger to do so?
Ta04-TRF, EVO 5
Futaba
KO Propo
Spintec
Old 03-04-2007, 12:38 AM   #1090
There has been some discussion about cooling the cells while charging them.
For sure your cells will accept more charge but you must realize that the temp reading is on the outside and thus the cut off temp as well. But inside your cells the temp is now much higher.
This could damage your cells.
This doesn't apply to the ICC only but for any temp cut-off charger.
MBreve is offline   Reply With Quote
Old 03-04-2007, 04:54 AM   #1091
because the icc is peak detection? temp for safety only?
Ta04-TRF, EVO 5
Futaba
KO Propo
Spintec
Old 03-04-2007, 08:05 AM   #1092
It uses both, whichever comes first.
But most of the time (with my IB4200's) the max temp is reached first.
Old 03-04-2007, 11:08 AM   #1093
Trader Rating: 25 (100%+)
So what is the verdict with the ICC charger? How does it work, and is it worth the money?
fred kellner is offline   Reply With Quote
Old 03-04-2007, 11:53 AM   #1094
To make a long story short. Conventional chargers will always under- and overcharge cells when they use either temp or delta peak to determine the cut-off point.
With the ICC this problem is solved and your cells will get the charge they should get. The results in better performance and a longer battery life.
For me, this is the major feature of the ICC but is has more and even more options will come in the near future.
Only drawback: This is no "plug and play" charger.
Is it worth the money? Depends on how serious a racer you are. If you don't true your comm, or discharge your packs with a light bulb the ICC will be overkill.
If you enjoy high tech stuff then this is a great charger.
Old 03-04-2007, 04:23 PM   #1095
I agree. If you are a willing to put in the effort and time into this charger, its well worth your money.
Ta04-TRF, EVO 5
Futaba
KO Propo
Spintec
Spintec ICC Charger MDawson R/C Items: For Sale/Trade 1 01-29-2008 09:05 AM
Spintec ICC charger ioxqq R/C Items: For Sale/Trade 2 07-15-2007 10:53 AM
Spintec ICC charger Dusty Kemp R/C Items: For Sale/Trade 1 10-27-2006 06:33 AM
Spintec Charger Nuno Gancho Electric On-Road 3 07-21-2006 04:32 AM
