spintec I.C.C charger >
Old 01-30-2007, 12:14 PM
  #1036
maybe you can try cleaning your contacts tips on the icc (since they are so small, i think it would make a difference if they were dirty)
(hehe i don't know, i am just guessing now), i notice that my 6th cell has issues sometimes too!
rcnewb2004 is offline
  #1037
I had another issue with 1.06c yesterday.
I had a 4 cell pack in setup to discharge before charge.
Started up fine and when I came back to it they had been on for an hour discharging, the pack had already been discharged to 4volts on my BatMan and the ICC was only dropping to .9 per cell, I scrolled along to the capacities and one cell was counting up but was only at 10mah and it stopped after a few seconds of me scrolling at 12 mah. all the readings were right 10-20 mah but it's like it didn't start discharging until I came back to it.
kiwirevo is offline
Old 01-30-2007, 12:16 PM
  #1038
The temp gun should always read lower than the ICC as the ICC measures the temp from the underside of the cell, which is surrounded by foam and there is no air flow . the temp gun is reading the top, where there is air flow
kiwirevo is offline
Old 01-30-2007, 03:54 PM
  #1039
Skiddins's Avatar
If you regularly get issues about cell voltage errors etc, it's probably the solder joints going inside.
I've had to re-solder mine twice now
Skiddins
Skiddins is offline
Old 01-30-2007, 04:13 PM
  #1040
Trader Rating: 22 (100%+)
Originally Posted by c-lyon
Yes, I increased the setting from 40*c to 45*c with 1.06c. I'll try a little higher. One thing that happens now is that cells 1, 2, and 3 ALWAYS reach temperature earlier than the others, when previously it varied. Anyone else notice this?
The difference is more than likely the internal resistance of the cells being different no cells are the same.
I have matched cells myself and found them to be a closer match than top quality matched packs, they are matched on disscharge rates which means one may take 400mah more charge than the cell next to it but disscharge at closer to the same mah.
That is why this charger is so good because normal chargers may overcharge 3 cells and undercharge 3 cells.
bjspinner is offline
Old 01-31-2007, 08:50 AM
  #1041
c-lyon's Avatar
Yes, it's just strange that it happens with all 9 packs. Yesterday I increased to 47*c on a pack and I'm getting close to the previous results on 1.06 at 40*c.
c-lyon is offline
Old 01-31-2007, 09:28 AM
  #1042
I am just wondering how does that compare to the temps on a temp gun?
thx skiddins, i wonder how a not well soldered joint will affect the IR reading and stuff on the icc....
Old 01-31-2007, 10:12 AM
  #1043
c-lyon's Avatar
I don't have one (I did but it went kaput). I'll borrow one on Friday, race day.
And I rarely get error messages...if I do, it's only a matter of moving the pack around a bit or cleaning the battery bars. And in case it matters my hardware is v1.2.
c-lyon is offline
Old 01-31-2007, 11:57 AM
  #1044
Skiddins's Avatar
Though I really like the charger it does have a very bad achilles heal.
The 'springs' that are used to make contact with the cells are only held on at the PCB end by a solder joint. Any electronic engineer will tell you that a solder joint should never be used to take any mechanical load (strain). Yet you can feel how much pressure there is when you move the lever. Sorry' it's bad design
Skiddins
Skiddins is offline
Old 01-31-2007, 04:32 PM
  #1045
I am no EE but i firmly agree that its a crappy design. They should well know that the spring will take a lot of strain... and it will be tested many many many times too... but they didn't do a good job w/ it... i think they partially expect the pcb to take the strain there too. good pictures... i need to learn how to open the charger up like that.. i can never get under it that way
I wonder if applying glue gun to it would do it any good, (except to make a mess)...
Old 01-31-2007, 04:42 PM
  #1046
Skiddins's Avatar
I don't think a glue gun or similar is anywhere near strong enough.
I have a couple of ideas for a mod to help prevent this but my design needs some fine tuning.
Watch this space.
Skiddins
Skiddins is offline
Old 01-31-2007, 06:38 PM
  #1047
FaiLip's Avatar
we found that by having the springs at close position while not in use reduces the strain. So maybe something to try and see whether it will improve the recurrence of this problem.
FaiLip is offline
Old 01-31-2007, 09:21 PM
  #1048
I am all eyes!
Old 02-01-2007, 01:53 PM
  #1049
Originally Posted by kiwirevo
I have just noticed something using firmware v 1.06c for a few minutes
If you change between the charge settings (IB4200, GP3700 etc) It doesn't remember to discharge before charge.
I was wrong, It won't remember if you don't charge on that setup.
But if you change it and then charge it'll be fine
kiwirevo is offline
Old 02-01-2007, 04:10 PM
  #1050
valleyraceway's Avatar
Default download
hey guys how do you download the newer 106c version i have the cable but my laptop is usb not serial port and when i try too down load the program it comes up cannot find hardware too open file how do you do all this thanks!!!
valleyraceway is offline
