Old 10-20-2006, 02:15 AM   #841
jtr
Hi everybody,
I have the interfacecable, problem is my laptop has no port to connect it to.
Are ther adapters so i can use the USB-port?
thanks in advantage.
Jasper
jtr is offline   Reply With Quote
Old 10-20-2006, 02:44 AM   #842
Pilot, send an email to [email protected]
I am sure he will help you out.
jtr, yes there are adapter cables available. Any pc store should have them.
aston is offline   Reply With Quote
Old 10-23-2006, 09:19 AM   #843
jtr
Unhappy
thanks, found the adapter cable!
still, followed all instructions in manual to upgrade and upgradetool said to have send all bytes, but now all memory on ICC is gone!
followed all instructions again in opposite order, to stay sure
then repeated all steps again according to manual
now the ICC does not respond on anything!
what can or shall I do now?
anyone?
Old 10-23-2006, 01:16 PM   #844
Send a message via ICQ to rcnewb2004
in theory, it will always stay in "update mode" incase a situation like this happens, (i have never done this before)... but i think you can try again.. from what i have read on this forum, the icc is hardwired to keep you on "update mode" unless a successful version of the icc is installed.
rcnewb2004 is offline   Reply With Quote
Old 10-23-2006, 07:28 PM   #845
Exclamation Blue Screen Only?
[QUOTE=jtr]thanks, found the adapter cable!
Is the charger display Blue?
With no words or letters?
Mine did that, and we noticed that the female connector on the board was not soldered correctly, or a cold joint. The plug itself had come off the board. The thing is very fragile.
I returned mine to Horizon and have heard nothing from them, they said they would retun it to Erik, but I have yet to hear from them,and it has been a long time
I returned it in July and have heard nothing.
So another sad story, about this $400.00 paper weight, well in my case now a $400.00 poor investment!
Good Luck !
smokerules is offline   Reply With Quote
Old 10-23-2006, 08:49 PM   #846
Send a message via ICQ to tough guy
I had problem updating the firmware too. It end up nothing wrong with the charger but it is my computer .So make sure you use (((8,n,1,))) (standard setting) on com 1. then you should be ok. if it doesn't work , just try on different computer with that setting.
tough guy is offline   Reply With Quote
Old 10-24-2006, 12:11 AM   #847
jtr
I had problem updating the firmware too. It end up nothing wrong with the charger but it is my computer .So make sure you use (((8,n,1,))) [COLOR=Blue](standard setting) on com 1. then you should be ok. if it doesn't work , just try on different computer with that setting.
Hi,
Charger has now the blue screen.
When updating, everything works fine, but then it stops uploading
It reaches approx. 190.000, statusbar is full then. When this happens i leave it for 10 min or so. Should there be a "done"or "ready" message??
Tough guy, i'm using another adaptercable to make it possible to use the USB-port. I do not have a serial-port.
I do not understand what you mean with the 8,n,1 setting?
I do have a race next weekend, please help.
JTRace
Old 10-24-2006, 05:37 AM   #848
Skiddins's Avatar
Originally Posted by jtr
Hi,
JTRace
I think he means ;
com 1 , 8 bit , no piority bit ,no hardware control, and 1
They are the Com port settings.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 10-25-2006, 12:31 AM   #849
jtr
Hi,
Where can i udjust those comport settings?
Jasper
Old 10-25-2006, 05:46 AM   #850
Skiddins's Avatar
Hi,
Jasper
In XP, they settings are in;
Control Panel, Performance & Maintenance, System, Hardware, Device Manager (These are the menus you need to select in order)
Look in the COM ports etc and look at the 'Properties' of the ports, you can change settings in there.
If you are using a USB to serial convertor I'm not sure how it will work.
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 10-26-2006, 11:45 AM   #851
jtr
hi,
i send Spintec an e-mail, hoping they will help me.
let you know what went wrong.
jasper
Old 10-27-2006, 05:25 PM   #852
jtr
Hi,
The problem is solved!
The problem was the serial to usb adapterkabel.
Took the ICC to a computer with a serial port, started upgrading
and worked fine.
thanks for helping!
Jasper
Old 10-27-2006, 06:30 PM   #853
BlueR1's Avatar
wow. it really amazes me what lengths people go to just to charge batteries. end of day, does it make you go faster?
i would think the time/money spent on using a laptop, etc etc would be better spent just practicing.
BlueR1 is offline   Reply With Quote
Old 10-27-2006, 08:21 PM   #854
This is a charger i invest in because if it lives up to its name, ICC will certainly save the batteries in the long run.
Old 10-27-2006, 08:53 PM   #855
adamkerrnz's Avatar
adamkerrnz is offline   Reply With Quote
Spintec ICC Charger MDawson R/C Items: For Sale/Trade 1 01-29-2008 09:05 AM
Spintec ICC charger ioxqq R/C Items: For Sale/Trade 2 07-15-2007 10:53 AM
Spintec ICC charger Dusty Kemp R/C Items: For Sale/Trade 1 10-27-2006 06:33 AM
Spintec Charger Nuno Gancho Electric On-Road 3 07-21-2006 04:32 AM
