spintec I.C.C charger >
Old 10-13-2006, 07:31 AM
  #826
Hey Skiddins, did u manage to get the entire board loose so you can solder it with the posts pointing towards the sky? it was really difficult to solder for me.
rcnewb2004 is offline
Old 10-13-2006, 07:52 AM
  #827
Originally Posted by rraden
Classic sign of "cold" solder joint. I hope Spintec sees these pics and corrects their production source. I'm strongly looking at one of these units but I'm still cautious due to the "issues" that they seem to have.
I may not be a cold solder joint, it may just be a lead free solder. Lead free solder joints tend to look like poor leaded solder joints.
Nick Malinoski
Nick_Malinoski is offline
Old 10-13-2006, 10:14 AM
  #828
Skiddins's Avatar
I left the PCB's in place.
I did have to pull the power leads through the side a bit so I could get the 'bottom' of the charger away from it.
Put it upside down on the bench and 'hey presto' I could get at all the joints.
I used some leaded solder with the iron at 350C, the solder went on easy though you do have to be carefull, the larger diameter cylinder looking bit on the spring is held in place by the solder
I think a good way of helping to prevent this problem is to make sure the lever is always set to the 'close' position when not in use.
Skiddins
Skiddins is offline
Old 10-13-2006, 07:51 PM
  #829
Good call. I believe the springs are under tension when it is in the open position. Wish I knew that before I left the country... they will be in the "open" position for the next ten months.
I suppose you don't anymore... but if u do... can u take a wide angle shot on the icc .... i just wanted to see what position it was in for me to be able to solder it again.
Old 10-13-2006, 08:28 PM
  #830
Trader Rating: 208 (100%+)
I leave mine in the closed position so not to put to much stress on the joints.
I wonder why Spintec has not been on the boards as of late?
dodgeguy is offline
Old 10-14-2006, 12:48 AM
  #831
They're in the middle of moving to a larger building in order to be able to keep up with the increasing demand.
MBreve is offline
Old 10-14-2006, 02:49 AM
  #832
Skiddins's Avatar
And presumably so they can get more people soldering
Skiddins
Skiddins is offline
Old 10-18-2006, 10:58 PM
  #833
Shop Owner
nnick's Avatar
I was wondering if it was possible to charge/discharge 6 separate cells before soldering them together.
nnick is offline
Old 10-19-2006, 03:09 AM
  #834
Lol they got me to do more soldering!
Old 10-19-2006, 05:42 AM
  #835
Skiddins's Avatar
Sort of....
Because assembled packs have battery bars, some of the 'prongs' that make contact with the batteries only make contact at the end of one cell, the battery bar would make the connection to the end of the next cell.
I think this is mainly for cell5.
The picture below has a plan view.
The other attachments show the charger in bits.
There is also a side shot showing the new bigger rubber feet that i fitted (allowing better air flow), the originals fell off when I first got it out of the box
Skiddins
Attached Thumbnails spintec I.C.C charger-spintec-plan-view-.jpg   spintec I.C.C charger-bar-position.jpg   spintec I.C.C charger-drowned-solder.jpg   spintec I.C.C charger-new-feet.jpg   spintec I.C.C charger-bench-ready-solder.jpg
Skiddins is offline
Old 10-19-2006, 10:06 AM
  #836
Skiddins's Avatar
This is the main lever bar in position
Skiddins is offline
Old 10-19-2006, 03:36 PM
  #837
coons88's Avatar
I'm interested to know. When you opened it up, is there alot of vacant space inside? Or is the whole unit packed with electronics?
coons88 is offline
Old 10-19-2006, 04:05 PM
  #838
Skiddins's Avatar
There are two circuit boards, the second is hard to see as the display is part of it.
On the lower main board, the only things that really stick down are the spring contacts for the cells etc, which are like large safety pins and the lever that controls them, there is room for other stuff if necessary but the only reason it's that tall is due to the springs contacts.
I was thinking about some sort of bar to go across the inside to help reduce the strain on the spring contacts when the lever is moved to the 'open' position.
Skiddins
Skiddins is offline
Old 10-20-2006, 12:42 AM
  #839
Default Big Problems
Just got my ICC and have a huge problem. When I charge a pack the charger doesn't recognize the delta peak cutoff or the temp cut off, it just keeps charging till the pack got super hot (I was lucky the cells didn't pop). Tried repeaking another pack and it did the same thing. I'm using IB3800 and IB4200 cells, a 6A chg, 4mv peak, no lockout and max temp at about 120. Any help on this problem would be greatly appreciated, until I get this thing fixed it's pretty much a $450 paper weight.
_pilot_ is offline
Old 10-20-2006, 12:54 AM
  #840
Here for Pre-Order $326
http://www.racing11.net/shop/product...oducts_id=1887
initialrays is offline
