Old 10-07-2006, 06:14 AM   #811
radio_car_racer's Avatar
Has anyone done a discharge comparison (produced graphs) using the same cells and discharger after charging on the Spintec ICC and another high-end charger?
radio_car_racer is offline   Reply With Quote
Old 10-07-2006, 04:41 PM   #812
coons88's Avatar
Send a message via MSN to coons88
Yes I have, I noticed basically no difference. Maybe slightly more when charged from the ICC, and by slightly I am talking less that 100mah, and a difference that small can vairy each time you do a discharge test anyway.
Associated TC6.1 | Hobbywing V3 | LRP X12 | Spektrum | Futaba | Reedy
coons88 is offline   Reply With Quote
Old 10-08-2006, 03:56 AM   #813
The main difference I find is that when each cell is charged individually, it also stops being charged when it is full.
With a plain charger that means that aproximately 2 cells are overcharged, 2 cells are charged well and 2 cells undercharged.
We all hate undercharged cells but what is more important is that the overcharged cells will drag the pack's performance down and the extra heat will slowly kill the cell.
Besides, this is a very good way to keep an eye on your pack's status. You know when tour pack is starting to deteriorate.
MBreve is offline   Reply With Quote
Old 10-08-2006, 06:13 AM   #814
Send a message via ICQ to rcnewb2004
I agree, if I had it my way, i would actually say this is the charger to get for all your not so peak performance packs, cause it will make sure cells that have deteriorated do not deteriorate any more due to over charging and make the packs stay good longer.
On a top notch matched pack, i am not expect this charger to do anyhting that will make it better.
rcnewb2004 is offline   Reply With Quote
Old 10-08-2006, 06:36 AM   #815
Used mine for the first time yesterday, had an operator error before the main but very happy with it's performance.
With all the cells being peaked individually, I think a matched pack would maintain it's match longer.
philb is offline   Reply With Quote
Old 10-08-2006, 10:19 AM   #816
I agree, the over- and undercharging with a regular charger will cause the match level to drop further faster.
rcnewb2004: You're probably right. But pack's are matched on discharge values and not on charge values.
Anyway, I'm very happy with it. I'm now using it to re-match my packs from 4 x 6-cell to 6 x 4-cell for the 1:12 winter season.
This way I know I have good packs and don't need to buy new ones for the winter. The ICC saves me money this way
Old 10-12-2006, 10:53 AM   #817
Send a message via ICQ to tough guy
Default upgrade problem sloved
i tried to upgrade the charger but once the process begin the program just disappeared on the screen and there was only blue screen on the display. So I tried the other computer using :
com 1 , 8 bit , no piority bit ,no hardware control, and 1.
the progrom started, and there was a progress bar. waited for 3 min.
It worked. So just make sure your setting is right.
before I used another computer, I called spintec.They answer it right away and I was told it will automatically switch to PC mode and this mode is hardware portected.
tough guy is offline   Reply With Quote
Old 10-12-2006, 03:54 PM   #818
Skiddins's Avatar
Originally Posted by rcnewb2004
i am happy again.... i don't know where i found the courage... but i took apart the icc.... found that one of the spring posts inside the icc was loose... popped it back into place... resoldered it... and i "think" it works again... i will find out if it does after i charge the pack!
Did you just have to solder around the larger diameter metal part of the spring?
I noticed the same thing today on mine,aftert taking the top off, at least two others are also loose
Hmm, not good for a very expensive charger.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 10-12-2006, 05:22 PM   #819
yes I did.... i agree.. that was not impressive.... but I realize i had to be very careful when inserting the pack... not to give the pins a "downwards" motion... must always ensure the pack is in... witihout pushing the pins downwards.
non the less... I still enjoy my icc charger and I think once it comes out with lipo charging ability and maybe a balance protector.... it will be even more awesome.
Old 10-12-2006, 06:25 PM   #820
Trader Rating: 198 (100%+)
I just hope my PC board never breaks where they mount at.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 10-12-2006, 10:26 PM   #821
it should not happen if you insert the pack carefully
asides from this... the icc is pretty durable!
Old 10-13-2006, 12:26 AM   #822
hey guys where is the best place to get one of these chargers at a good price from a reputable mail order place? thanks..
speedpro1 is offline   Reply With Quote
Old 10-13-2006, 12:40 AM   #823
XrayFK's Avatar
$349.99: http://www.thercshack.com/index.asp?...OD&ProdID=4503
XrayFK is offline   Reply With Quote
Old 10-13-2006, 05:40 AM   #824
Skiddins's Avatar
Here are some pics of what to look for just in case anyone else wants to know what the problem is.
Shots are looking up at the PCB from the underneath;
First one is a main post that has come off, the second shot is of a dry joint that is about to go.
I'll be re-soldering all of them after work .
spintec I.C.C charger-spring-contact-de-soldered.jpg   spintec I.C.C charger-spring-contact-dry-joint-loose-.jpg
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 10-13-2006, 08:26 AM   #825
rraden's Avatar
Trader Rating: 235 (100%+)
Classic sign of "cold" solder joint. I hope Spintec sees these pics and corrects their production source. I'm strongly looking at one of these units but I'm still cautious due to the "issues" that they seem to have.
Xray XB8E 2016 | Xray XB4 2017 | Xray XB2 DE 2017 | Xray XB8 2017
Dirt Burners - Livonia, Mi
The Track - Carleton, MI
rraden is online now   Reply With Quote
Spintec ICC Charger MDawson R/C Items: For Sale/Trade 1 01-29-2008 09:05 AM
Spintec ICC charger ioxqq R/C Items: For Sale/Trade 2 07-15-2007 10:53 AM
Spintec ICC charger Dusty Kemp R/C Items: For Sale/Trade 1 10-27-2006 06:33 AM
Spintec Charger Nuno Gancho Electric On-Road 3 07-21-2006 04:32 AM
