spintec I.C.C charger >
Old 08-06-2006, 01:57 AM
  #721
gee-dub's Avatar
Originally Posted by Seano
So basically you are using the temp peak only? I would assume 0mv cutoff means that the delta peak is turned off altogether? What temp settings are you using?
good question, i do not honestly know if that turns it off or not (i am hoping not, since if a battery does not sit all the way down against one of the temp sensors, it could damage a cell). i am using temp peak of 124F.
i haven't really paid attention, but it would be nice if when a cell peaks, instead of saying full, it said something like full/pk or full/tmp to differentiate how the charge cycle stopped.
gee-dub is offline
Old 08-06-2006, 03:11 PM
  #722
JohnMatrix's Avatar
I feel a difference off the bat.
It took me awhile to get it working. Update and settings. Setting are the key, the numbers are different than our old chargers.
My settings for IB 3800 are 6 or 7 amps, 4.0mvs, 50c, 180 sec force charge.
The difference I feel is not at the beginning of the race but at the end. The batts are staying constant through the five min.
Has anyone charged a practice pack, and ran it till it died? Notice how it goes from medium fast to a crawl at the end of practice? Cause all the cells are done at the same time, imo. I could be way off.
JohnMatrix is offline
Old 08-09-2006, 09:41 PM
  #723
HELP!!!!
For some reason... one of hte pins won't push against the battery pack anymore!!!! what should i do? i bought my charger during my visit to HK and now i am in canada ...
rcnewb2004 is offline
Old 08-09-2006, 09:44 PM
  #724
Originally Posted by rcnewb2004
HELP!!!!
Probably you want to drop Erik an email...
Ben.C is offline
Old 08-09-2006, 10:21 PM
  #725
Trader Rating: 202 (100%+)
John I have found that the pack does stay strong longer. But I am using the CTX-D for discharge. After a run I pulse discharge until .9v per cell. Some packs the cells have different mah left. And my packs I have very good numbers from SMC and Full Throttle. Not all cells discharge at the same rate. We hope they do. But they do not.
dodgeguy is offline
Old 08-09-2006, 10:30 PM
  #726
i am happy again.... i don't know where i found the courage... but i took apart the icc.... found that one of the spring posts inside the icc was loose... popped it back into place... resoldered it... and i "think" it works again... i will find out if it does after i charge the pack!
Old 08-14-2006, 11:26 PM
  #727
danjoy25's Avatar
Trader Rating: 37 (100%+)
FYI
Would there be a possibility of increasing the external charge rate to 6 amps by releasing a software upgrade? Or is this only achievable via hardware upgrade?
Yes, we think that should be possible. We are testing with it, looks like we can increase the rate to 6 amps for 6 cell charging. For 4 cell we are not sure yet.
Fingers Cross this update happens.
danjoy25 is offline
Old 08-14-2006, 11:58 PM
  #728
Another question... not sure if it has been mentioned before...
when i am charging a pack in the tray at 6A and one on the external output at 5A.... i get only a 10A draw (when i look at the system info section)...
any ideas why?
Old 08-15-2006, 12:44 AM
  #729
coons88's Avatar
If your interested, check out the videos on the Orion website, there is a video on the ICC and the BatMan V2 with Erik Jonk. The new BatMan looks cool
coons88 is offline
Old 08-15-2006, 12:49 AM
  #730
BringItOn's Avatar
you got a link?
BringItOn is offline
Old 08-15-2006, 01:07 AM
  #731
coons88's Avatar
Originally Posted by BringItOn
you got a link?
www.teamorion.com/media
OR
ICC
http://www.team-orion.com/media/ita06-spintec_icc.wmv
BatMan V2
http://www.team-orion.com/media/ita06-spintec_bm-v2.wmv
coons88 is offline
Old 08-15-2006, 01:34 AM
  #732
is it any store who has the icc in stock?
EnÖ_Design is offline
Old 08-15-2006, 01:40 AM
  #733
BringItOn's Avatar
thanks cheese man
Old 08-15-2006, 01:49 AM
  #734
Thanx for the link! I've been waiting for this for a long time, so long I forgot to check the website regular.
MBreve is offline
Old 08-16-2006, 05:31 AM
  #735
Skiddins's Avatar
Originally Posted by Smartypants
Heres my response from Helger UK
Hello
The charger is now being produced and we have samples here in the UK. We have them on oder with Spintec and should get them very soon The retail price is £274.99
Thank you
Tried phoning again today, Helger still don't have a delivery date!
Eric, can you shed any light on when the UK will have some?
I wanted to use one at the KO Grand Prix but it is looking doubtfull.
Skiddins
Skiddins is offline
