spintec I.C.C charger
#587
Originally Posted by Patriiick
i saw the cable last week and it looked awfully standard to me, with something that looked a lot like the turbo 35 GFX so my guess is that it will be quite close.. (bought the ICC, but not the cable)
#589
Sorry if this was discussed before, but is it possible to charge and discharge the cells as one by one or do they have to be soldered as a battery pack ?
#590
The spintec I.C.C chargers are NOW in stock at Brooklyn hobbies
Please call the store at 718-951-2500 for more information.
#591
With the cell discharge, can you set the voltage cut-off for all the cells, or is it a 'pack voltage'?
Skiddins
Skiddins
#596
Originally Posted by abarth
Hello all.
I just got this charger yesterday and I tried it out.
I think mine had some problems. It charges really really slow. I don't think I'm doing anything wrong. I did it just like how the manual discribe to set it up. I started to charge and waited for about 30- 40 min to check how it idoing. The charging count was only up to 035mAh! The Battery is still new.
I only used this IB4200 twice before this charge. It was set for 5.0A charge.
Anyone had this problem? Should I send it back to repaire? Sorry for my poor English and Thank you for your time.
Abarth
Abarth
#597
Skiddins
Skiddins
#599
Originally Posted by XrayFK
If you know how to use Excel it is easy as pie. Not sure, but the ICC may automatically graph the data if you send it to a PC. The graph will show up in Hyperterminal. You can still use Excel though for a nicer looking graph.
#600
I don't have an ICC, so I don't know if there are any different specific parameters for the connection. I know that with the CE chargers, you connect through HyperTerminal. In HyperTerminal you make a new connection choosing "Direct to ComX#" Parameters for the CE are:
Bits per second: 9600
Data bits: 8
Parity: None
Stop bits: 1
Flow Control: Hardware
After that you can send the data from the charger and it will show up in HyperTerminal. From HyperTerminal you can save the data as a TXT file and import it into Excel and do whatever you wish with the data.
Keep in mind that the parameters I gave are for the CE but who knows, it might work as well with the Spintec. Your best bet would be to contact Erik.
Data bits: 8
Parity: None
Stop bits: 1
