spintec I.C.C charger
#466
It's out, I have it.
#467
Got any good info, pics? battery charging information? anything on this charger? it seems ppl possess it, but no one has posted anything extensive about this product...
i hope it becomes available to the masses soon... cause its been over a year now... i have been waiting for this charger... it better be worth all the time i have posted on this thread!
#468
Tech Legend
Trader Rating: 51 (100%+)
Originally Posted by grazianos
Any update on the timing for this? [Please no "two weeks" jokes]!
#469
Skiddins
#470
My batteries accept 300 mAh average more than before.
Rob Janssen.
Rob Janssen.
#471
are those charge or discharge numbers?
#472
charge numbers.
Didn't discharge a full pack yet.
#473
Mine will be here either this week or next . I'll post my impressions of it and how well it works as soon as I can after I get it
#474
Sean, your one have just arrived today. I have tested mine and I am impressed. Screen is clear, does everything it say it would. Best thing other than the individual charging would be the individual charge time, temp, voltage and capacity. I am loving it, and this is not bias.
#475
Where and when can i get mine?
#476
I will be in HK in june, so want to know if that will be avaliable there...
#477
I've been testing mine now and do have one problem. When trying to charge from the external output while charging in the tray, I get a "powersupply out of range" error. Guess it's my powersupply that dosent deliver enough amps. Wierd, cause it's a +20 amps supply.
#478
After charging it for 5sec. on my overloader it was no problem anymore.
Rob Janssen.
#479
Found the problem. It wasn't the charger, it was indeed my power supply. I'm using a modified PC supply. After hooking up the second pack using the external output, the voltage would drop below 12 volts which resulted in the "powersupply out of range" error.
Discovered another thing today. While charging my IB4200, I forgot to change the chrage setting from GP3700 or IB4200. Dunno if that was the cause, but cell #1 started cooking bad. It litteraly spewed it's guts out on the + side, at the end of the charge. Disconected it immidiately and checked the charger. No harm done. Checked the battery, looked fried, but just to be sure, I ran a voltmeter through it. Still 1,51 volt, about the same as the other 5 cells, so no harm done. However, the pack itself will be closely watched next time I charge it up.
Dunno if the wrong setting did this or the cell is just about dead. Looking at the voltage, it's not.
Will test further.
Will test further.
#480
jan larson
jan larsen
your ib4200 cells ! were you step charging them ?
