Old 04-27-2005, 02:12 PM   #1
Default Switching from Tamiya to Deans
Im finally going to be switching from Tamiya plugs to Deans plugs in my TC3. Does anybody have any thorough step-by-step instructions/tips on this?
I know HOW to do it---but this is actually my first attempt at installing Deans plugs and dont want to screw anything up obviously. I can solder, and I have all the equipment/parts/tools to do the job. Ive found a little info here and on the web, but nothing too detailed.
So if anybody has a link or can make a post with good step by step tips/directions, I would really appreciate it.
Thanks.
RaceFan3 is offline   Reply With Quote
Old 04-27-2005, 02:56 PM   #2
koabich's Avatar
Send a message via Yahoo to koabich
It's really as easy as soldering the leads from the battery to the deans connectors. No special instructions needed, unless you don't know how to solder.
Just make sure that the female connectors are solder to the battery. This will help eliminate the pack from shorting out on anything while it's not plugged in.
koabich is offline   Reply With Quote
Old 04-27-2005, 03:50 PM   #3
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
good choice of using the deans.
I melt alot of tamiya connectors before.
KREATOR1 is offline   Reply With Quote
Old 04-27-2005, 03:51 PM   #4
rcgen's Avatar
Another trick is to connect the male and female together while soldering the wires on the female end. This prevents the connecter on the female end from moving around because the connector tends to melt the plastic if you hold the iron too long. Also, you may also want a third hand. Other than that is a simple process.
rcgen is offline   Reply With Quote
Old 04-27-2005, 03:56 PM   #5
KREATOR1's Avatar
oppss!!! always put your male deans to the ESC. no male connectors on batt. may short your batt.
Old 04-27-2005, 07:03 PM   #6
KoE
KoE's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to KoE
RaceFan3,
try looking at Balak's page on soldering
Yo!
KoE is offline   Reply With Quote
Old 04-27-2005, 08:57 PM   #7
I glanced at that page the other day, but forgot about it. Thanks for the reminder KoE !
Old 04-28-2005, 12:04 AM   #8
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
2 things
1. Remember to slide your shrink wrap well down your wire BEFORE you solder the leads. (I alsways seem to forget after not doing one for a while) If you leave them slid on too close to the plug the heat transfered while you solder may shrink the tube where you dont need/want it.
==========|||-- <-Me on a bad day
=======\\\\\|||-- <-Me on a good day
2. I've only tried a few different types, but I really like the heat shrink that comes with teh dean plugs better than anything else. I would recomend making sure you use it as the other brands/types I have used end up pulling down when I try to disconnect the plug after its installed
3 pin Deans for easy switching from brushless to brushed. Katana Man Electric On-Road 22 07-14-2007 06:57 PM
Deans ultra plug, Dish rims with tires, Tamiya Pinions Peter_PaP Australia Wanted to Buy 2 06-27-2007 11:48 PM
Serpent starter box,Deans discharger,Deans battery jig,Indi battery equalizer SRAD R/C Items: For Sale/Trade 5 03-14-2007 05:32 PM
switching from EP to GP uniquexme Nitro On-Road 4 05-24-2006 05:23 AM
Help with switching to 30%. rcpilot Nitro On-Road 17 06-21-2002 07:56 AM
