Old 02-11-2013, 10:25 AM   #1
Default SPRINT 2 SPORT TROUBLE
I have a sprint 2 sort, i recently dropped in a element by castle 3900 4 pole. So anyway my belt seems to tighten and pop when i turn the gears or drive it. Could it be the belt or something? Thanks
IRIEirieIRIE is offline   Reply With Quote
Old 02-11-2013, 05:01 PM   #2
Front belt? Rear belt? anything stuck in them? Pics? Vids? Come on, can't help you without a better description of the problem.
2013 HPI Mini Recon
2012 HPI Sprint 2 Sport
1983 Marui Samurai
Slobalt7 is offline   Reply With Quote
Old 02-11-2013, 11:11 PM   #3
Is seems to only be the front belt, nothing looks Stuck, I've Taken apart the whole front diff and couldn't find anything.. And when i drive the car forward/reverse the front belt seems to tighten then loosen.
Old 02-12-2013, 01:36 AM   #4
heretic's Avatar
We need pictures.
Or, I've always been an advocate of the " tear down and rebuild " method. Pretty much self explanatory. Your car won't have any secrets for you after that.
I love wedge bodies. I love dish wheels.
heretic is offline   Reply With Quote
Old 02-12-2013, 11:31 AM   #5
NO PICS..PHONES A PIECE OF SHIT ANYWAY I TOOK IT TO THE LOCAL HOBBY SHOP THEY SAID IT WAS SOMETHING IN THE DIFF TOTALLY TOOK IT APART COULDNT FIND ANYTHING WRONG. BUT THE FRONT BELT SEEMS TO GET ALOT OF TENSION AND THEN SUPER LOOSE. COULD IT BE A GEAR PROBLEM I HAVE A 23 PIN AND 90 SPUR. SEEMS LIKE SOMETHING IS LOCKING CAUSING THE TENSION BUT I CANT FIGURE IT OUT...
Old 02-12-2013, 11:59 AM   #6
something is stuck in your gear. so the belt cant fully seat itself in there. pull the diff out and get an exacto knife and clean out every notch.
ninjlao is offline   Reply With Quote
Old 02-12-2013, 12:43 PM   #7
There's only 3 movin parts:
mainshaft pulley pinned to the mainshaft turns
the front tensioner turns
the front diff turns
Start eliminating suspects.
Belt tightening & loosening while in different phases of use is normal.
The belt COULD be getting hung up on the upper deck or the ESC wires or there's something jamming like pebble or one of the infamous loose HPI bulkhead nuts, etc.
Just a friendly tip, boy - using cap locks pretty much tells how old you are or how old you mind is.
Maybe you best back off the cap locks and act respectful from here on out.
If you're pissed off about something go kick your old man in the nuts for his part in the grand scheme of things.
-Dutch- is offline   Reply With Quote
Old 02-12-2013, 12:43 PM   #8
by gear Im talking about the belt gear. Just to clear it up. I dont know what else to call it, but I am almost positive that you have buildup of gunk in there, which happens to pretty often.
Old 02-12-2013, 12:51 PM   #9
When you put in the new motor, did you by any chance move or remove the left motor mount or the main shaft?
How tall is the battery you are using? Does the belt hit it?
Old 02-12-2013, 02:21 PM   #10
Jeremy Mullins's Avatar
I've had a similar issue when I purchased a front one-way diff. The machining was off and the belt pulley was off center. It created a tight belt / loose belt issue. Also got a pinion gear with the same issue.
Give the belt some slack and while the tires are off the ground give it some throttle and look for anything that might be off.
AE TC6.1 WC - AE RC8.2e - AE SC10 4x4 FT - AE T4.1 FT - TLR 22 - HB TC-FD - HPI Sprint 2 Drift - Blade 120sr
Jeremy Mullins is offline   Reply With Quote
Old 02-12-2013, 02:48 PM   #11
Marv's Avatar
Back track your install of the motor and ESC.
You may have screwed something up, didn't get parts back they way they came out, forgot to put something back in... could be any number of things.
Kinda rough going with so little info.
Here's a wild-ass guess =
Sounds like one of the bearing holders/eccentrics for the main shaft (in the motor mounts) is off a tick or two on one side...
Marv is offline   Reply With Quote
Old 02-12-2013, 02:51 PM   #12
Marv's Avatar
Pulleys.
They're called pulleys.
The main shaft pulleys are 15 teeth each and the diff pulleys are 32 teeth each
aka as 15T pulley and 32T pulley.
Manuals are here = http://www.hpiracing.com/instructions/#Kits
Old 02-12-2013, 04:29 PM   #13
I am thinking this, I did it when I cleaned my bearings but realized it before I ever ran it. Something just looked funny so I popped off the clip and found it. I would think it would have wore down one side of your belt but idk.
2013 HPI Mini Recon
1983 Marui Samurai
