Battery Bars vs Braided Wire
#46
Originally posted by jdwca
BTW, Seaball, not to hijack, but make sure you and Jim come on out to our race in June.
#48
I know, I was afraid of rubber tires too.
#49
Ray - I can't tell you how many times this happens with people. I've actually had this happen with team drivers in the distant past. I'll give them the same quality cells I built for myself, but they'll complain that it only cycled at 1.165V or something and mine cycled at 1.185V. When you try to explain to them that they possibly soldered incorrectly or applied too much heat or used cruddy bars or something, they cannot believe it would make such a difference.
Regarding soldering/unsoldering, I usually just tell guys to purchase new packs once they're considering rezapping/rematching. Usually the cells have developed so much memory by then, the only thing to do is sell them or deadshort them if they haven't already done so.
As Seaball said unsoldering and resoldering old packs is generally a no-no for competition racing.
Could you share your method of soldering a pack together. I have 2 new packs that have good numbers, but I don't want to damage them when assembling.
Cheerz
#50
Originally posted by speedxl
[B]yes copper , silver , Gold have very low numbers of resistance and they are very close. The ability to not corrode is a big factor on what metal to use because that in it self can raise resistance. Here is a small list of materials in order of conductivity that would surprize some of the guys on here!
* silver
* copper
* gold
[B]
* silver
* copper
* gold
[B]
Platinum
Gold
Silver
Are the top 3
From 1980's you’ll never see PC cards in your computers have a silver plated cards.
There are Gold plated cards, wonder why?
Obviously you and I will never see Platinum plated PC cards. The last time I saw Platinum something was when I bought her a wedding ring!
#51
I know I bought my wife a ring too.
The cost of platinum is to high. Instead of paying 5 to 10 dollars for bars you'd be getting finacing at a jewler for battery bars. Imagine paying atleast $1,000 dollars for I pack!
Sea ball acyually in performance on the long run you'll get more bang for the buck performance wise because your batteries will last longer.
Those connectors you use if they were crimped then yes there would be an increase in performance because every time you heat up the wire to solder there is a property in the wire ( I cant remember the term) that deminashes and corrosion settles in thus raising resistance which over time you may think your batteries fell off which in fact it may be wires need to be replaced!
As far as connectors I know someone who has won a few A mains and placed in the A at a roar national and at the Snowbirds. So to me when someone says connectors are bad I laugh. By the way he used deans plugs.
His name Kevin Mitchal.
#54
Seems as though I remember hearing that Platinum only becomes a better conductor at high temps. From what I understand the resistance in Gold, Silver, and Copper goes up pretty quickly when temps starting getting really high.
I think that's the "theory" behind Platinum spark plugs, I may be wrong though. It just seems like I remember reading about that somewhere.
#55
Which is the reason for a material that can handle High voltage and withstand temperatures exceeding 1500 degs.
We on the other hand can get away with a softer material.
#59
Looks great. Believe me, I've seen *all kinds of connections*. Guys will bring their packs up to me and I've got to be kind sometimes.
I used Orion bones exclusively before the Promatch bars. I just thought they were really trick looking too. My only beef with the bones is that they're a small contact area compared with the Promatch. I'm being picky...
#60
no in pure form? in PURE pure i think its
gold
silver
copper.
gold
silver
copper.
