Old 02-10-2013, 12:02 PM   #1
Default Shock Rebound
Hi guys.
Could someone please explain what this does to you car handling wise in reflection to the rear/front etc and what conditions you would use it in and why.
i tend to always run 0% mainly because i dont understand what it does, but everyone else seems to run it.
Nathan
Nathan Wilson is offline   Reply With Quote
Old 02-10-2013, 02:38 PM   #2
sosidge's Avatar
The effect on handling is incredibly small, at most it is in the region of changing your spring rate by about half the gap between the closest springs you can buy. Just build the shocks in a way that you find consistent.
Old 02-10-2013, 07:22 PM   #3
Mr RCTech's Avatar
Originally Posted by Nathan Wilson View Post
Hi guys.
Nathan
More noticeable in off-road tracks.
Smooth tracks less to no rebound.
Bumpy tracks more rebound.
Comes down to personal handling.
On-road sedans I would run 1/2 rebound in the front and
no rebound in the rear.
Mr RCTech is offline   Reply With Quote
Old 02-11-2013, 01:06 AM   #4
Thanks, so more rebound makes that end of the car slightly stiffer? And none softer?
Old 02-11-2013, 06:07 AM   #5
spencehotbodies's Avatar
Hello
I have always found that no rebound always works better on a bumpy track over a smooth track.
spencehotbodies is offline   Reply With Quote
Old 02-11-2013, 09:51 AM   #6
SS LS1's Avatar
Trader Rating: 23 (100%+)
Originally Posted by spencehotbodies View Post
Hello
Or even negative rebound for bumpy tracks works great.
Tamiya 417v7 Sedan, ___ Tamiya 417v7 USGT, ___ CEFEX EVO w/ 417 suspension VTA
Exotex TA06 Pro CS Drifting, ___ Tamiya 417v5 (sold)
AE SC10 4x4
AE SC10 AE B4.11
SS LS1 is offline   Reply With Quote
