Old 04-25-2005, 07:31 AM   #1
Default FK'05 failed thrust bearings only
If you have an FK'05 in which the thrust bearings failed, please post here...
I'm afraid to pull my diffs apart, for they feel terrible, and if the thrust bearings have failed I won't be running the car for awhile.
Of the 4 other guys I knowpersonally, who run the car, 2 have had the thrust bearings fail.
MartynD is offline   Reply With Quote
Old 04-25-2005, 07:48 AM   #2
komkit's Avatar
Send a message via ICQ to komkit Send a message via AIM to komkit Send a message via Yahoo to komkit
Most if not all thrust bearing with metal retainer ring will fails in no time. The one that has a “copper” look a like retainer rings will last for a long long time.
Both of my original thrust bearings fell apart after 6 packs (may be failed before I took it apart). The guy sitting next to me didn’t make it past the first 4-5 packs.
If your replacement one got the metal retainer ring it may fail again. Look for the “copper” looking one. All else fail Corally RDX thrust bearing will fit and it has a copper retainer ring.
Xray must have bought the thrust bearing from two different manufacturers.
CFX Paintworks - The Track
komkit is offline   Reply With Quote
Old 04-25-2005, 08:01 AM   #3
Lonestar's Avatar
Why create a separate thread for that?
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 04-25-2005, 08:04 AM   #4
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
It's sad because they clearly annouce that the new t1'FK05's will have the carbide thrust bearings. Clearly this is not the case because I took mine apart first thing to check for lube (none btw, but the 12 dif balls did have minimal amount of grease), and they did not have the "copper" thrust bearings like I had when I made the switch to carbide in my 04 Xray. I feel this is false advertising since each carbide thrust bearing is atleast 22$ to replace and we the customers didn't get them.
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 04-25-2005, 08:07 AM   #5
Lonestar's Avatar
Fine. They screwed up on the thrust bearing and yes you need to shelf an extra $22. The rest of the car is absolutely, positively, brilliantly superb and definitely the best bang for the buck on the market today. Is their mistake worth another thread? I think not... hence i will stop posting here btw... Just my 2cts
Paul
Old 04-25-2005, 08:09 AM   #6
Trader Rating: 45 (100%+)
Post
I was the guy sitting next to komkit who had the axial bearings fail. First the front diff then the rear. Anyhow, luckily some racers had extra axial bearings that fit the diff. If the diff is pretty rough, most likely you'll have to rebuild and replace the axial bearing. The copper cage axial bearing will definitely fix your problem. Checkout Team Xray's forum page on their website for more information about this.
Apex is offline   Reply With Quote
Old 04-25-2005, 08:11 AM   #7
Paul
AGREED!!!
Old 04-25-2005, 08:11 AM   #8
My point is that they did not deliver on what was promised and they try and conceal it with offering a pre-built dif that lacks grease. Very smart Xray!
Old 04-25-2005, 08:14 AM   #9
The reason for starting a new thread is to make it more visible. I talked to the Canadian Distributor who said he had only heard of one case in Canada, yet I know 2 others myself. There are lots of posts saying the same thing in the FK thread yes, this is an attempt to organize them.
And lets not forget its at least $22 each, 2 diffs = $44
There is no support for Corally here, and very very little for Losi.
Old 04-25-2005, 08:18 AM   #10
Rob Phillips's Avatar
speaking of promises, how about the multi diff*
*not available in the USA kits
Team Durango | TrakPower | DE Racing | Futaba | Restricted Paint Worx
Velocity R/C Magazine - vrcmag.com
Rob Phillips is offline   Reply With Quote
Old 04-25-2005, 08:28 AM   #11
Shop Owner
nnick's Avatar
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
My friends and I all experienced the same thing (3 fks)
Nick
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
Team Xray T4'17, Team Xray X10'18, TOP Racing Rebel
nnick is online now   Reply With Quote
Old 04-25-2005, 11:21 AM   #12
Martyn,
As you probably know ... you can add me to the list.
I love the car - but to cheap-out on the axial bearings - disappointing!.
To reply to those that question why the seperate post ... to bring attention to a problem and hope that there are enough replies to cause X-Ray to look into this a little more seriously then they appear to be.
duckman996 is offline   Reply With Quote
Old 04-25-2005, 11:33 AM   #13
HarshGuy's Avatar
I have one that went critical mass
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 04-25-2005, 11:43 AM   #14
syndr0me's Avatar
Trader Rating: 32 (100%+)
My RDX had two of the "silver" type thrust washers in the diffs, both of which went bad immediately. Corally USA sent me two copper thrust bearings, including new washers for free, and admitted that these parts were defective. They did the same thing for people that got aluminum diff pulleys that heated up and melted diff balls.
Not trying to start a debate between manufacturers, but if there's an obvious problem, the right thing to do is address it, not try and sweep it under the rug and tell people "too bad, we're XRay" as some have suggested. They obviously make an awesome car. If there's a flaw, they need to own up to it. To do anything else is bad business.
Thanks to the guy who created this thread. It's often up to consumers to keep companies honest.
syndr0me is offline   Reply With Quote
Old 04-25-2005, 11:58 AM   #15
dgullickson's Avatar
Trader Rating: 45 (96%+)
Send a message via AIM to dgullickson Send a message via Yahoo to dgullickson
What size is this thrust bearing?
dgullickson is offline   Reply With Quote
(2) NIP Slapmaster Diff Thrust Bearings Apex R/C Items: For Sale/Trade 8 12-11-2007 10:48 AM
thrust bearings Collins Australia For Sale/Trade 0 04-10-2007 01:54 AM
NEW FK'05 bearings Rogier R/C Items: For Sale/Trade 3 01-31-2007 01:32 PM
Ceramic balls for diff and thrust bearings Still Bill Electric On-Road 1 02-27-2005 01:05 PM
Picco synchro clutch thrust bearings Turbo9000 Nitro On-Road 11 02-10-2003 01:00 PM
