Old 02-13-2013, 04:51 PM   #46
Mr RCTech's Avatar
Originally Posted by SS LS1 View Post
If I understand correctly you use the oil mix with high traction to help prevent the buildup of track rubber on your tires, correct?
Yes, the trick is not to use too much in the mix.
Also, to remove heavy tire buildup Goo Gone works well too.
Mr RCTech is offline   Reply With Quote
Old 02-13-2013, 06:15 PM   #47
tmomedrano's Avatar
Originally Posted by bvoltz View Post
What is your take on using Brake Fluid?
based on experiments... nothing. used DOT3. i even mixed it with my home brew... it took away traction.
[ Team Maxx Traxx ] http://iloveporrc.blogspot.com/ * http://timmedrano.com
tmomedrano is offline   Reply With Quote
Old 02-13-2013, 06:24 PM   #48
I'll have to throw in a different oil to try. But I've had the same stuff for many years- STP oil treatment. I tried the PB blaster got the info from a GoKart guy said it help soften the tires. You can alway hide the smell and looks with food coloring and flavors.
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT-12 Racing USA (21.5 ), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 02-15-2013, 08:15 AM   #49
SS LS1's Avatar
Trader Rating: 23 (100%+)
Originally Posted by Mr RCTech View Post
Now your on the right path.
I add about 5% of mineral oil or caster oil.
You can use PB Blaster works well too for an oil mix.
I use the 50/50 for cleaning the tires.
Then use a oil in the 50/50 mix as traction gos up on carpet racing.
I was cleaning my tires and rebuilding my shocks last night and thought I would ask Mr.Tech if there is any reason why you couldn't use shock oil as the 5% oil additive over say caster oil? PB blaster and caster oil have some decent smells. Shock oil could help keep the mix clear (no staining) and odors down to keep from offending other racers or spectators. Thoughts?
Tamiya 417v7 Sedan, ___ Tamiya 417v7 USGT, ___ CEFEX EVO w/ 417 suspension VTA
Exotex TA06 Pro CS Drifting, ___ Tamiya 417v5 (sold)
AE SC10 4x4
AE SC10 AE B4.11
SS LS1 is offline   Reply With Quote
Old 02-15-2013, 08:54 AM   #50
I wouldn't think it's a good idea to get anything silicone based anywhere near your tyres...
cyclonetog is offline   Reply With Quote
Old 02-15-2013, 03:28 PM   #51
Mr RCTech's Avatar
I tried the shock oils.
Silicon tends to lay on the surface of the tire loosing traction.
Linseed oil, caster oil, or PB Blaster mixes well and penetrates the rubber.
Linseed oil mix works well on asphalt as well as caster oil.
PB Blaster work well for both carpet and asphalt.
Experiment.
Please post your findings here.
I would be interested in your thoughts.
Old 02-15-2013, 04:20 PM   #52
Marv's Avatar
From what I remember from auto tech classes =
Brake fluid is hygroscopic = attracts & retains moisture
And has a high boiling point = heat resistant
Why use brake fluid if it attracts moisture and resists heat?
Marv is offline   Reply With Quote
Old 02-15-2013, 06:29 PM   #53
Skiddins's Avatar
Hence;
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 02-16-2013, 03:05 PM   #54
Metalsoft's Avatar
Trader Rating: 69 (100%+)
I have always just used DAWN dish washing soap after each run. Makes em tacky, cleans them well, no scent, and it doesn't burn my eyes out.
Tamiya TB03 USGT - Custom Carbon fiber Chassis - Magoo Racing Inc....
Metalsoft is offline   Reply With Quote
Old 02-16-2013, 03:13 PM   #55
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
Simple green works as well for cleaning tires...
OVA is offline   Reply With Quote
Old 02-16-2013, 04:07 PM   #56
Professor's Avatar
+1 the concentrate type,we also have a watered down version here in aus which does not work very well
Professor is offline   Reply With Quote
Old 03-05-2013, 01:59 PM   #57
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Marched in to the store last night. Got the Coleman fuel and mineral spirits. Just read about the mineral or castor oil additive to slow evaporation. So, back to the store tonight to get that oil. Going to try the 60/40 + 5% oil mix first.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 03-05-2013, 03:40 PM   #58
SS LS1's Avatar
Did you buy the gallon metal can of Coleman fuel or the smaller red can (fuel for the weekend) of Coleman fuel? I believe it is the same just sold in a smaller quantity.
AE SC10 4x4
AE SC10 AE B4.11
Old 03-07-2013, 06:33 PM   #59
Wally world only had the gallon cans. Then the paint dept for the odorless mineral spirits. Still need the oil though before Sunday racing. I'm doing a side by side with SXT 3.0.
Old 03-07-2013, 08:56 PM   #60
SS LS1's Avatar
John, please post your results when you can. I have not experimented yet as I have a lot of SXT3.0 left to use up this winter season.
After talking to some sponsored drivers they all said they coat their tires with WD40, wipe clean then reapply WD40 and let dry between rounds. Then they apply SXT3.0 about 10 mins before they are up to race. This was on a med-high grip track so I guess the WD was softening their tires and the "fish oil" left behind was helpful to reduce rubber buildup on the tires. (based on what Mr RC Tech had said here.)
Thoughts?
AE SC10 4x4
AE SC10 AE B4.11
