Old 02-08-2013, 12:18 AM   #16
wollow86's Avatar
Originally Posted by Mornedn View Post
Any other comments or thoughts?
I've always liked the d3. I've used one with both tekin and speedpassion and it's been very strong. When mine finally let go, I replaced it with a D3.5 which so far doesn't feel that much better. It does like a slightly taller fdr then the d3. I always felt like I had the power edge with my D3 at our home track. As a bonus the D3 is slightly cheaper then the most of the current crop of motors.
Supporting Aussie hobby shops:
- www.MRJRacing.com.au - - www.feralbatteries.com.au - - www.actionrc.com.au -
wollow86 is offline   Reply With Quote
Old 02-08-2013, 01:21 AM   #17
YEah I have the same view. Problem is tha 3.5 in now illigal and the D3 not available anymore.... so I'm stuck. X12 is also good, but it does not work with the GT2 pro esc
Mornedn is offline   Reply With Quote
Old 02-08-2013, 01:23 AM   #18
Has anyone tried the X12 17.5 with the Hobbywing v3?
Old 02-08-2013, 04:02 AM   #19
If the kv ratings of two different motors are more or less the same , does this mean that they are very similar when it comes to torque and performance?
Gerrie is offline   Reply With Quote
Old 02-08-2013, 04:55 AM   #20
Benzaah's Avatar
Trader Rating: 21 (96%+)
I ran D3 with a HW V2.1, then the VST pro and D3.5 with R10 pro. D3 is not as fast as VST but VST likes less pinion to work. The VST is a really good boosted motor. The new VST2 looks even better. I can't wait for it to come out.
Adelaide RC - XRAY Xb216de & Xb416
Walter Rc Hobby - Serpent 4X
Nosram - R1wurks - Sanwa - Hudy - Muchmore
Benzaah is offline   Reply With Quote
Old 02-08-2013, 05:09 AM   #21
daleburr's Avatar
KV ratings are largely meaningless, you'll never hear any racer at the track even mention them.
Performance of a motor is determined by its power curve, which only track or dyno testing will allow you to compare.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 02-08-2013, 05:35 AM   #22
Thanks for the info. Just thought they might be more or less the same. It could have made a few things a bit easier for me when changing motors
Old 02-09-2013, 12:16 PM   #23
Reese Bobby's Avatar
While a motor's KV rating may not give the whole picture in terms of performance, it certainly measures a valid performance metric. I dont think its coincidence the D3.5 was banned and it has the highest 17.5 KV rating I could find.
Does anyone have some insight into the SchuurSpeed motor's KV rating?
VBC Wildfires
Orca - Revolectrix - Sanwa - SMC
Reese Bobby is offline   Reply With Quote
Old 02-09-2013, 12:27 PM   #24
LOW ET's Avatar
Trader Rating: 97 (100%+)
why does the x12 not work with the gt2?
LOW ET is online now   Reply With Quote
Old 02-09-2013, 06:49 PM   #25
rangerjkb's Avatar
Trader Rating: 40 (100%+)
Send a message via MSN to rangerjkb
For Boosted application, I would recommend a Murfdogg Synergy. If interested contact Matt Murphy at [email protected] and he can build you one specifically for your needs.
Jason Burks
Psycho Cells Racing~Hal's Hobby Warehouse~Murfdogg Products~Avid RC
rangerjkb is offline   Reply With Quote
Old 02-11-2013, 04:40 AM   #26
Some of the other racers tried the combo and those motors run
hot compared to other motors . They battle to get the temps under
100 deg C
