12V solder iron?
12V solder iron?
I have bought one that writes: 40W but nothing.
You have to wait for some min. so as to solder your wires onto the battery.
Anyone knows a good 12V iron 50W+?
Or should i go for one gas powered?
Donīt know of the trickbits iron but MRT also have a 12V iron. From what I remember itīs rated at 40W but beside the watts the size of the tip is one thing what is important also. And MRT always have some quality stuff so this should be good also.
At the MRT thread you can find a picture.
http://www.rctech.net/forum/attachme...postid=1080092
If you have further question you should contact Terry.
From down under, batteries, motor wires no sweat, full heat in 3 seconds!.
http://www.telesound.co.nz/shop/shop...OLDERING+IRONS
Cheers
Peter
Cheers
Peter
Any picture on this?
I am curious too.....
Re: 12V solder iron?
[i] Or should i go for one gas powered? [/B]
I'll try to attach a Photo.
The black collar on the iron is the on/off switch. Push towards the tip is on. Downside of the quick heat up is if you leave the heat on too long it will melt the tip. You learn after the first time.
Cheers Peter
Cheers Peter
Mr Alonso
I think these come from Melbourne, as usual can't find instructions but they have "Warren and Brown" on the label.
12v 30w-180w.
Cheers
Peter
12v 30w-180w.
Cheers
Peter
Isn't it a little expensive?
New Zealand $85 = approx US$60 = approx 40 Euros
Don't know how that compares with your local prices for a similar specification item, it's a good buy here, but we are used to paying a little more because it is a small market/country.
All spare parts are available to keep it in top condition, see above for one reason for needing spares.
Cheers Peter
Cheers Peter
What about irons that use gas?
Anyone uses one?
Anyone uses one?
I use a Portasol butane powered iron. It hasn't let me down yet.
http://shop.store.yahoo.com/cinemasu...e-psl100k.html
