Old 08-04-2002, 09:30 PM   #1
Default Rookie here, Battery question maintenance
i have several 2400 battery packs by team orion. and thinking about getting some 3000 MINAH batteries
what maintenance can i do to prolong their life?
discharger team orion digital
959 superbrainer charger
1. how low do i discharge them to?
2. how to store them short term and long term (charged or discharged)
3. after i discharged them. the voltage reads 1 V. then approximately 15-20 minutes later, the voltage increases to approx. 6V IS THIS NORMAL?
4. How long after do i "zap" the NICAD to erase the memory? how many cycles?
5. 2400 NICAD or 3000 MiNAH which ones are better?
6. how to maintain 3000 MINAH batteries.
7. same questions above for 3000 minah batterys
thanks in advance.
M3Jokster is offline   Reply With Quote
Old 08-04-2002, 10:50 PM   #2
Fire's Avatar
All your questions were answered in the Sanyo 3000HV forum
in quick you can't go wrong with 3000HV
Fire is offline   Reply With Quote
Old 08-05-2002, 05:08 AM   #3
sosidge's Avatar
Default Re: Rookie here, Battery question maintenance
1. I'd suggest 5.4v
2. Discharged, although with NiMH's it's better to put a part charge in if stored for more than a fortnight.
3. Yes - in fact the voltage should return to about 7.2v
4. Zapping is not a commonly used process - it's used by the matchers, but few people do it once they've bought the cells. NiCD memory can normally be erased quite well by cycling.
5. I would say 3000 HV's or SMH's
6 and 7. I recommend the advice at www.smc-racing.com
Old 08-05-2002, 06:07 AM   #4
hobbipro's Avatar
Trader Rating: 21 (100%+)
Try www.promatchracing.com I've been following their care instructions with excellent results.
hobbipro is offline   Reply With Quote
Stupid rookie question about the TC4 Blisster Rookie Zone 1 12-15-2006 08:20 PM
Airbrush rookie question about what to get? Key500 Painting, Designs, Graphics and Photography 14 12-23-2005 06:19 PM
just a general rookie question BoneHead Rookie Zone 9 12-13-2004 11:08 AM
WTB: A/C battery charger for rookie DC5R R/C Items: Wanted to Buy 8 08-24-2004 02:41 PM
half rookie question batman19 Rookie Zone 23 04-01-2004 03:26 PM
