Tamiya TT02 Thread
#3451
Either way, its too bad Tamiya hasn't made an adjustable piece like this.
The fixed unit can work, but you need to "trial-and-error" to figure out which combination of 64p spur and pinion works for the various hole pairs.
#3452
Ah, That's clearer, I see it now - the center opening is a bit more oblong, looks like they managed an extra degree or two at each end...Either way, its too bad Tamiya hasn't made an adjustable piece like this.The fixed unit can work, but you need to "trial-and-error" to figure out which combination of 64p spur and pinion works for the various hole pairs.
#3453
Question about Tamiya Datsun 240Z bodies- have a TT02 and they have two bodies listed One says TT01 - will this body fit the TT02?
#3456
Does anyone know of a good TT02 Setup Sheet for carpet and or asphalt? Also what differential viscosity should I be running for carpet?
#3457
Have fun with this car on carpet. I ran a TT02 Type S my first year of racing....the car was unbeatable on asphalt....handled like it was on rails. Brought it indoor onto carpet, was like driving a school bus. Tons of oversteer that I could not dial out no matter what settings I changed.
#3460
looking for some TRF shocks for my stock TA-02. Everywhere is outta stock. Do they not make them anymore? This is my daughters car for practice & scooting around the house. She will eventually race in novice with the car. Just looking for a quality upgrade over the friction dampers
#3465
