Tamiya TT02 Thread >
Tamiya TT02 Thread
Like Tree935Likes
Tamiya TT02 Thread
    Hide Wikipost
Old 01-14-2021, 03:44 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Tamiya TT02 Thread
Last edit by: pparrett
TT02 Wiki - Post your setups, upgrades and home grown ideas here for us to read...
TT02 vs the TT-01
http://www.thercracer.com/2013/01/ta...irst-pics.html
New flat chassis layout - Easier to run LiPOs vs the cutouts in the TT-01s
Revised suspension geometry
Support for std spur gears
MODELS ----------------------------------------------------
Changes that follow are in comparison to the basic kit.
TT02 - Base Kit. Friction Dampers.
TT02D - Drift: Drift Tires, Hardened A-Parts, Oil Shocks
TT02R - Race: Rear Alu 3* Toe In Hubs, Alu Propshaft + Cups, CVA oil Dampers
TT02RR - Race+: TT02R + Adjustable Upper Arms, Oil Filled Diffs, Hardened Blue Chassis
TT02S - Type S: TRF416 arms, FRP shock towers, bearings,
TT02SR - TypeS Race: TT02S + Double cardan front drive shafts, rear lightweight universals, Rear sealed oil differential, front spool
TT02B - Buggy. Offroad: CVA Shocks, Double Wishbone long suspension
HOP UPS ----------------------------------------------------
Bearings:
#54476 Ball Bearing Set TT02: 8x 1050, 4x 1280, 4x 1150
Propshaft:
#54501 Alum Propeller Shaft TT02
#54502 Alum Propeller Joint TT02
Tip:
Put a 3mm piece of well greased silicone hose between the dog bone and the shaft of each wheel to reduce slop.
Motor Mount and Gearing:
#54558 TT02 Aluminum Motor Mount
#54500 High Speed Gear Set
#54875 Oil Gear Differential
Steering:
#54550 Low Friction Step Screws
- Full Upgrade Kit -
#54752 Steering Upgrade Kit, Includes all below.
- Individual Parts -
#54574 Aluminum Steering Set
#54575 Aluminum Steering Bridge
#54799 Hi-Torque Servo Saver or #51000 Servo Saver Black
#54248 Aluminum Turnbuckles 3x23
#50797 5mm Short Adjustable Turnbuckle End
Dog Bones to Universal Joints:
- Standard Steel -
#53792 Universal Shaft Assembly (steel), NOTE: Must also use item 54477 on the TT-02
#54477 Gearbox Joint for Universal Shaft (steel) (2pieces)
- Lightweight -
#53506 Blue Aluminum 39mm Swing Shaft
#53499 Wheel axle for assembly universal
#53681 Titanium wheel axle for assemblu universal (but this is very expensive)
#53500 cross joints for universal
#54477 Gearbox Joint for Universal Shaft (2pieces)
Tip: Run steel in the front, Alu is okay for the rear but the front takes a lot of wear and impact from crashes
Shock Options:
#54753 Super-mini CVA Oil Shocks, comes with med black springs
#42102 TRF 55mm Shocks
Chassis:
#54639 Carbon Damper Stay Front
#54640 Carbon Damper Stay Rear
#47339 Hard Lower Deck Blue
#47340 Hard Lower Deck White
#54926 Hard Lower Deck Black
#54733 Aluminum Rear Uprights, Gives 3* rear toe in for extra stability
#54549 Aluminum Rear Uprights, 2.5* Rear Toe In
#58584 Hardened A-Parts, Uprights, Hub Carriers, Diff Covers, etc
SUGGESTED BASE SETUPS ----------------------------------
Bashing:
Build to the kit instructions and have fun!
Asphalt Parking Lot Racing:
Front Diff: 300k-500k (or Tamiya #42247 Gear differential putty)
Rear Diff: 3K oil in the rear diff for low / medium grip, 5k oil in the rear for medium / high grip
Carpet Indoor Racing:
Rear Diff: 7k -10k in the rear diff for very high grip carpet.
ADDITIONAL RESOURCES -------------------------------------
TT02 Build and Review here
http://www.thercracer.com/2013/05/ta...nd-review.html
TT02 Tuning and Mods Guide
http://www.thercracer.com/2014/08/ta...-and-tips.html
https://www.rcdriver.com/take-the-versatile-tamiya-tt-02-chassis-to-the-next-level/
Gearing for 17.5t Blinky
http://www.thercracer.com/2013/07/ho...inky-with.html
Print Wikipost
Old 02-23-2020, 08:43 AM
  #2341
chucko's Avatar
Default tires
Originally Posted by Hoyle33 View Post
What's your tires of choice for street bashing?
I don 't bash.lol I race only.. I used the ones that came in the kit BUT they did not come with inserts. it took me a week of googling to find the parts. after searching Rc mart was first to order.. a month later got em glued em raced it didn't like the looseness sliding... went to A-main got some foams they work great. Amain has some good stuff then I ordered some stuff on ebay and found nitro hobbies .com has great fast shipping and a lot of TT 02 items rctech ,com and about ten others in the usa has great parts. google or ebay for tires
chucko is offline
Old 02-23-2020, 11:01 AM
  #2342
Hoyle33's Avatar
Trader Rating: 15 (100%+)
I think inserts are my issue. What inserts did you decide on?
Hoyle33 is offline
Old 02-23-2020, 11:56 AM
  #2343
SteveM's Avatar
Trader Rating: 165 (100%+)
Don't forget that you'll need 26mm inserts.
SteveM is offline
Old 02-24-2020, 04:04 AM
  #2344
Hoyle33's Avatar
None of the inserts I find online have sizes. Any idea what size these are?
https://www.sweepracingusa.com/10th-...A-H_p_208.html
Hoyle33 is offline
Old 02-24-2020, 04:11 AM
  #2345
SteveM's Avatar
All the Sweep inserts are likely 24mm as that is the standard today. HPI used to sell both 24mm and 26mm tires and inserts and my Tamiya TT-01e Mercedes 190e kit came with 26mm rims and tires. I was lucky to have an old set of foam (not moulded) inserts that I used. HPI part number HPI4676 and not ideal but better than no inserts.
SteveM is offline
Old 02-24-2020, 04:22 AM
  #2346
SteveM's Avatar
Tamiya 26mm hard inserts are part number 53835, soft are part number 53834. The Vaterra cars used 26mm tires as well and Amain sells the tires with foam inserts for $13 either slicks or treaded.
SteveM is offline
Old 02-25-2020, 10:00 AM
  #2347
proliteandsc's Avatar
Tamiya super grip tire 53214 made for asphalt.
Tamiya hard sponge set 53156. That's the only ones I found. Most others been discontinued.
proliteandsc is offline
Old 02-26-2020, 07:09 AM
  #2348
Has anyone tried 64p gears in the TT-02
rippen is offline
Old 02-26-2020, 08:14 AM
  #2349
What question are you trying to answer? Yes, lots of people have/do.
rippen and KA2AEV like this.
Nerobro is offline
Old 02-26-2020, 09:00 AM
  #2350
Can you use the Tamiya aluminum motor mount still
rippen is offline
Old 02-26-2020, 09:20 AM
  #2351
In theroy, yes. If you're talking about Part: 54558 You'd need to adjust your pinion spacing by gear choice.... But that's silly when an adjustable motor mounts are $8.
rippen likes this.
Nerobro is offline
Old 02-26-2020, 10:20 AM
  #2352
SteveM's Avatar
Your best bet is to purchase the TT-02 high speed gear set #54500 and a Yeah Racing adjustable motor mount. I have both parts still NIB.
SteveM is offline
Old 03-08-2020, 08:13 PM
  #2353
Default Hobbywing quicrun 1060 esc
Hello....new to the thread. I'm waiting for the TT02SR to be released so I can get one. I need an esc for it and can't understand the TCS spec/novice class rules on which esc can be used. Can someone tell me if the quicrun 1060 is legal or do i need to use the tamiya tble02 esc? Thanks for the help
jamsandolina is offline
Old 03-09-2020, 12:39 AM
  #2354
Can anyone confirm this. During the tamiyacup here I drove my tt02rr and it was not fast in lap time. After talking with the A final people. They say that they were 0.5 seconds slower with the diffs of the tt02rr and therefore rode with the diffs of the tt02r. I think it's a strange story and I think you have to adjust the setup to get the most out of it.
arnold1000 is offline
Old 03-09-2020, 12:41 AM
  #2355
Double post
