Tamiya TT02 Thread >
Tamiya TT02 Thread
Like Tree898Likes
Tamiya TT02 Thread
    Hide Wikipost
Old 01-14-2021, 03:44 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Tamiya TT02 Thread
Last edit by: pparrett
TT02 Wiki - Post your setups, upgrades and home grown ideas here for us to read...
TT02 vs the TT-01
http://www.thercracer.com/2013/01/ta...irst-pics.html
New flat chassis layout - Easier to run LiPOs vs the cutouts in the TT-01s
Revised suspension geometry
Support for std spur gears
MODELS ----------------------------------------------------
Changes that follow are in comparison to the basic kit.
TT02 - Base Kit. Friction Dampers.
TT02D - Drift: Drift Tires, Hardened A-Parts, Oil Shocks
TT02R - Race: Rear Alu 3* Toe In Hubs, Alu Propshaft + Cups, CVA oil Dampers
TT02RR - Race+: TT02R + Adjustable Upper Arms, Oil Filled Diffs, Hardened Blue Chassis
TT02S - Type S: TRF416 arms, FRP shock towers, bearings,
TT02SR - TypeS Race: TT02S + Double cardan front drive shafts, rear lightweight universals, Rear sealed oil differential, front spool
TT02B - Buggy. Offroad: CVA Shocks, Double Wishbone long suspension
HOP UPS ----------------------------------------------------
Bearings:
#54476 Ball Bearing Set TT02: 8x 1050, 4x 1280, 4x 1150
Propshaft:
#54501 Alum Propeller Shaft TT02
#54502 Alum Propeller Joint TT02
Tip:
Put a 3mm piece of well greased silicone hose between the dog bone and the shaft of each wheel to reduce slop.
Motor Mount and Gearing:
#54558 TT02 Aluminum Motor Mount
#54500 High Speed Gear Set
#54875 Oil Gear Differential
Steering:
#54550 Low Friction Step Screws
- Full Upgrade Kit -
#54752 Steering Upgrade Kit, Includes all below.
- Individual Parts -
#54574 Aluminum Steering Set
#54575 Aluminum Steering Bridge
#54799 Hi-Torque Servo Saver or #51000 Servo Saver Black
#54248 Aluminum Turnbuckles 3x23
#50797 5mm Short Adjustable Turnbuckle End
Dog Bones to Universal Joints:
- Standard Steel -
#53792 Universal Shaft Assembly (steel), NOTE: Must also use item 54477 on the TT-02
#54477 Gearbox Joint for Universal Shaft (steel) (2pieces)
- Lightweight -
#53506 Blue Aluminum 39mm Swing Shaft
#53499 Wheel axle for assembly universal
#53681 Titanium wheel axle for assemblu universal (but this is very expensive)
#53500 cross joints for universal
#54477 Gearbox Joint for Universal Shaft (2pieces)
Tip: Run steel in the front, Alu is okay for the rear but the front takes a lot of wear and impact from crashes
Shock Options:
#54753 Super-mini CVA Oil Shocks, comes with med black springs
#42102 TRF 55mm Shocks
Chassis:
#54639 Carbon Damper Stay Front
#54640 Carbon Damper Stay Rear
#47339 Hard Lower Deck Blue
#47340 Hard Lower Deck White
#54926 Hard Lower Deck Black
#54733 Aluminum Rear Uprights, Gives 3* rear toe in for extra stability
#54549 Aluminum Rear Uprights, 2.5* Rear Toe In
#58584 Hardened A-Parts, Uprights, Hub Carriers, Diff Covers, etc
SUGGESTED BASE SETUPS ----------------------------------
Bashing:
Build to the kit instructions and have fun!
Asphalt Parking Lot Racing:
Front Diff: 300k-500k (or Tamiya #42247 Gear differential putty)
Rear Diff: 3K oil in the rear diff for low / medium grip, 5k oil in the rear for medium / high grip
Carpet Indoor Racing:
Rear Diff: 7k -10k in the rear diff for very high grip carpet.
ADDITIONAL RESOURCES -------------------------------------
TT02 Build and Review here
http://www.thercracer.com/2013/05/ta...nd-review.html
TT02 Tuning and Mods Guide
http://www.thercracer.com/2014/08/ta...-and-tips.html
https://www.rcdriver.com/take-the-versatile-tamiya-tt-02-chassis-to-the-next-level/
Gearing for 17.5t Blinky
http://www.thercracer.com/2013/07/ho...inky-with.html
Print Wikipost
Old 03-13-2019, 09:33 AM
  #1891
wtcc's Avatar
Rock solid! I glued the two upper plastic parts under the wing together and also used shims between body and wire clamps. The way Tamiya wants it with just o-rings has little play.
wtcc is offline
Old 03-16-2019, 11:13 PM
  #1892
crazykoolrn's Avatar
Originally Posted by 1/8 IC Fan View Post
Is the gear Diff that comes in the TT02 Type S the same as the RR Gear Diff? Just curious, are the changes only the Seals and O-rings on the RR Diff? Looking to get a few parts together for my son to try some TC.
N/M EDIT: I see in the Instructions that they are different GB1 vs GB2 (Case)
completely different diffs.
Tamiya will release the RR diff at some point, however, 3racing makes a sealed diff for the tt02.
crazykoolrn is offline
Old 03-17-2019, 07:32 AM
  #1893
1/8 IC Fan's Avatar
Trader Rating: 102 (100%+)
Yes, I had gathered that earlier.
We will see how the 3racing diffs do.
Although the RR Diff Has already been announced Tamiya TT-02 oil-filled gear differential - Red RC - RC Car News
1/8 IC Fan is offline
Old 03-17-2019, 02:45 PM
  #1894
wtcc's Avatar
The 3racing diff is ok. Just make sure to remove every bit of slop in the transverse axis and keep the distance of the gear teeth small. Also check after the first and second day of running. Otherwise it will start to slip and ruin the teeth.
wtcc is offline
Old 03-21-2019, 11:33 AM
  #1895
proliteandsc's Avatar
Default TT-02S or Shumacher M1v2 or 3racing Sakura Xl sport
Looking to race in the VTA with a 25.5T brushless motor. It's a small track in a parking lot. Anyone have any experience with the two cars. Wondering which one would be better? What spare parts would I need? Does anyone have setup sheets for black top tracks?
proliteandsc is offline
Old 03-21-2019, 11:40 AM
  #1896
Raman's Avatar
Trader Rating: 85 (100%+)
I donít know much about Schumacher cars.. looking at it on their website itís a superior car to the TT02.. plastic tub chassis vs dual deck graphite.
Raman is offline
Old 03-31-2019, 08:17 AM
  #1897
Default Electrical problems
I have a tt-02 with the tble-02 esc and brushed motor that came with it. Using a Spectrum DX4C radio with the AVC traction control reciver. Worked fine for few weeks. Now the ESC stop working started blinking red and then went up in smoke. Tried another tble-02 ESC and noticed it getting hot just plugged in. Then I installed new motor. The LED on it turns green like it should when using it, but now it only has brake and reverse. Not sure what to do next. The LHS told me it could be the AVC reciver or because I removed all the tamiya plugs and soldered a better battery plug and directly to the motor. I used that reciver on 2 other cars with no problems. The others were brushless. I checked voltage at motor ends. Full throttle went to about 11v then back down to about 6v. Brake about 6v and reverse about 3v. Anyone have this problem?
Old 03-31-2019, 03:06 PM
  #1898
Raman's Avatar
Changing plugs would not cause these problems. Iím not familiar with the AVC receiver but Iím guessing itís probably the culprit. To be honest you donít need traction control. Between my son and myself we own 2 dozen RC cars, 8 of which we race.. none use such a feature.
Raman is offline
Old 03-31-2019, 03:38 PM
  #1899
ShadowAu's Avatar
The Schumacher Mi1 is not graphite, it's fiberglass with special finish call S1
ShadowAu is offline
Old 03-31-2019, 03:41 PM
  #1900
11v? Are you trying to use a 3s battery on a 2s speed controller?
Nerobro is offline
Old 04-01-2019, 09:43 AM
  #1901
It's a 5000 mhA 30c 2s. Thought the 11v was some boost from a capacitor in the ESC. It very quickly went back down to about 6v.
Old 04-01-2019, 10:07 AM
  #1902
That's not how that works, and the TBLE02 only has a linear regulator for BEC. 11v is still concerning. I don't know where that would be coming from. Want to post a photo of your setup?
Nerobro is offline
Old 04-01-2019, 07:43 PM
  #1903
BladeRunner24's Avatar
Default Here is the new gt4 mustang on tt02 chassis
30th anniversary car
Tamiya gt4
BladeRunner24 is offline
Old 04-01-2019, 09:07 PM
  #1904
I did insert the bind plug in AVC disable plug after all this started to see if it would help. Didnt work.
Old 04-01-2019, 09:17 PM
  #1905
I wired it like this before the problems started. This is my other one with a different servo.
