Tamiya TT02 Thread >
Tamiya TT02 Thread
Like Tree936Likes
Tamiya TT02 Thread
    Hide Wikipost
Old 01-14-2021, 03:44 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Tamiya TT02 Thread
Last edit by: pparrett
TT02 Wiki - Post your setups, upgrades and home grown ideas here for us to read...
TT02 vs the TT-01
http://www.thercracer.com/2013/01/ta...irst-pics.html
New flat chassis layout - Easier to run LiPOs vs the cutouts in the TT-01s
Revised suspension geometry
Support for std spur gears
MODELS ----------------------------------------------------
Changes that follow are in comparison to the basic kit.
TT02 - Base Kit. Friction Dampers.
TT02D - Drift: Drift Tires, Hardened A-Parts, Oil Shocks
TT02R - Race: Rear Alu 3* Toe In Hubs, Alu Propshaft + Cups, CVA oil Dampers
TT02RR - Race+: TT02R + Adjustable Upper Arms, Oil Filled Diffs, Hardened Blue Chassis
TT02S - Type S: TRF416 arms, FRP shock towers, bearings,
TT02SR - TypeS Race: TT02S + Double cardan front drive shafts, rear lightweight universals, Rear sealed oil differential, front spool
TT02B - Buggy. Offroad: CVA Shocks, Double Wishbone long suspension
HOP UPS ----------------------------------------------------
Bearings:
#54476 Ball Bearing Set TT02: 8x 1050, 4x 1280, 4x 1150
Propshaft:
#54501 Alum Propeller Shaft TT02
#54502 Alum Propeller Joint TT02
Tip:
Put a 3mm piece of well greased silicone hose between the dog bone and the shaft of each wheel to reduce slop.
Motor Mount and Gearing:
#54558 TT02 Aluminum Motor Mount
#54500 High Speed Gear Set
#54875 Oil Gear Differential
Steering:
#54550 Low Friction Step Screws
- Full Upgrade Kit -
#54752 Steering Upgrade Kit, Includes all below.
- Individual Parts -
#54574 Aluminum Steering Set
#54575 Aluminum Steering Bridge
#54799 Hi-Torque Servo Saver or #51000 Servo Saver Black
#54248 Aluminum Turnbuckles 3x23
#50797 5mm Short Adjustable Turnbuckle End
Dog Bones to Universal Joints:
- Standard Steel -
#53792 Universal Shaft Assembly (steel), NOTE: Must also use item 54477 on the TT-02
#54477 Gearbox Joint for Universal Shaft (steel) (2pieces)
- Lightweight -
#53506 Blue Aluminum 39mm Swing Shaft
#53499 Wheel axle for assembly universal
#53681 Titanium wheel axle for assemblu universal (but this is very expensive)
#53500 cross joints for universal
#54477 Gearbox Joint for Universal Shaft (2pieces)
Tip: Run steel in the front, Alu is okay for the rear but the front takes a lot of wear and impact from crashes
Shock Options:
#54753 Super-mini CVA Oil Shocks, comes with med black springs
#42102 TRF 55mm Shocks
Chassis:
#54639 Carbon Damper Stay Front
#54640 Carbon Damper Stay Rear
#47339 Hard Lower Deck Blue
#47340 Hard Lower Deck White
#54926 Hard Lower Deck Black
#54733 Aluminum Rear Uprights, Gives 3* rear toe in for extra stability
#54549 Aluminum Rear Uprights, 2.5* Rear Toe In
#58584 Hardened A-Parts, Uprights, Hub Carriers, Diff Covers, etc
SUGGESTED BASE SETUPS ----------------------------------
Bashing:
Build to the kit instructions and have fun!
Asphalt Parking Lot Racing:
Front Diff: 300k-500k (or Tamiya #42247 Gear differential putty)
Rear Diff: 3K oil in the rear diff for low / medium grip, 5k oil in the rear for medium / high grip
Carpet Indoor Racing:
Rear Diff: 7k -10k in the rear diff for very high grip carpet.
ADDITIONAL RESOURCES -------------------------------------
TT02 Build and Review here
http://www.thercracer.com/2013/05/ta...nd-review.html
TT02 Tuning and Mods Guide
http://www.thercracer.com/2014/08/ta...-and-tips.html
https://www.rcdriver.com/take-the-versatile-tamiya-tt-02-chassis-to-the-next-level/
Gearing for 17.5t Blinky
http://www.thercracer.com/2013/07/ho...inky-with.html
Print Wikipost
Old 07-24-2017, 09:49 AM
  #1501
Metalsoft's Avatar
Trader Rating: 75 (100%+)
Originally Posted by kawi650 View Post
Me and my cousin just picked up some TT02Rs for some cheap parking lot racing action. The first couple runs were essentially stock with the addition of the Yeah Racing adjustable motor mount running 17.5 motors. I had some 64P pinions and spurs left over from another car so I threw in 81/47 gearing and things were much better (and it could probably use another couple teeth on the pinion).
My cousin, understandably, cannot let my car be so much faster than his so he will be changing gearing as well. The difference is he would like to stick with 48P gears for some added durability with the target ratio is something in the 4.3 FDR range. I tested 55/33 with some spare gears I had and they did not come close to meshing so I'm thinking something around 60/36 would work. Can anyone give me a 48P recommendation for a 4.3ish FDR that will fit?
All you need to know right here
Tamiya TT02 17.5 21.5 and VTA Blinky Gearing | The RC Racer
Metalsoft is offline
Old 07-24-2017, 10:02 AM
  #1502
Originally Posted by Metalsoft View Post
I read all that, it is very helpful when using 64P gears.
I'm looking for gearing in 48P to get a FDR in that range to prevent buying gears that don't fit. Like I said, the first guess with 55/33 gearing did not come close to actually meshing.
kawi650 is offline
Old 07-24-2017, 10:09 AM
  #1503
Metalsoft's Avatar
You can get the high speed gear set, then order what ever 48P gears you would like.
WHile he did use 64P, you can use this as a guide for 48 as well.
Old 07-24-2017, 10:34 AM
  #1504
lilws6's Avatar
What gears fit on the tamiya high speed setup. I need to regear for the 17.5 and want to make sure I get a 64p that will fit
lilws6 is offline
Old 07-24-2017, 10:38 AM
  #1505
Metalsoft's Avatar
I know the kimbrough fit without issue..
Old 07-24-2017, 10:42 AM
  #1506
lilws6's Avatar
Cool I was thinking they would fit but wasn't sure the pictures I was seeing of them made me think twice about ordering right away.
lilws6 is offline
Old 07-24-2017, 11:41 AM
  #1507
EbbTide's Avatar
Trader Rating: 39 (100%+)
These are the gears I'm using in my TB03. I believe they can be used with the TT02
TowerHobbies.com | Robinson Racing Spur Gear 60T Stealth Pro
EbbTide is offline
Old 07-24-2017, 12:17 PM
  #1508
LJH
be careful going to small with the gears, I originally bought a 77T spur and a 44T (64P) and the diameter of the motor prevented the gears from meshing, not enough adjustment travel. I then went to a 85T spur and a 51T pinion and that put me pretty much in the middle of the adjustment on the YR adjustable motor mount.
As long as you go with a spur around 85T (64P) you can cover a wide range of FDR's.
Cheers,
Jim
LJH is offline
Old 07-24-2017, 01:29 PM
  #1509
fyrstormer's Avatar
That's where running wider-pitch gears comes in handy -- the teeth are taller as well as wider, so even if you can't get a *perfect* gear mesh due to limitations in the motor-mount adjustment, you can still get an *acceptable* gear mesh. 48-pitch (aka Mod 0.53) gear teeth are about 0.35mm taller than 64-pitch gear teeth, which means you can get away with having the motor positioned about 0.7mm further away from the spur gear than is ideal, and the gears will still mesh well enough to drive the car. If you can make the jump to Mod 0.6 without losing the ability to get the gear ratio you want, you can get closer to 1mm of leeway in the gear mesh.
fyrstormer is offline
Old 07-24-2017, 02:33 PM
  #1510
Raman's Avatar
Trader Rating: 85 (100%+)
Cheers,
Jim
Hey Jim,
I run 78T/51T on my TT02S for racing which gives me a 3.98 fdr. The motor I use is a 21.5 and it never temps above 120°.
You will need to grind the gear cover, mine has an opening.
Raman is offline
Old 07-24-2017, 04:27 PM
  #1511
Originally Posted by Raman View Post
They Rereleased the body under 43453. Its just the body too, no decals / livery, no masking,
https://www.tamiyausa.com/items/radi...a-nsx-gt-47353
cool. found it at Rcmart - cheap too.
Tamiya 1/10 Honda NSX-GT Lightweight 2005 Clear Body Parts Set #47353,
cplus is offline
Old 07-25-2017, 07:11 AM
  #1512
Trader Rating: 73 (100%+)
Roughly equal to a 80T 64p.
nitrostarter is offline
Old 07-25-2017, 10:40 AM
  #1513
Originally Posted by cplus View Post
Yep they are even available in Europe so I have a couple. They are not legal in TCS races though. (Although that probably doesn't affect you in Australia)
Qatmix is online now
Old 07-28-2017, 08:37 PM
  #1514
lilws6's Avatar
This thing is a mess of tires right now. Hpi is not on my good list at the moment. can't find tires wheels are impossible to get. 🙁 Either way I got to run it a little bit. Running 82t spur and 49t pinion she scoots pretty good. Doesn't seem to turn very tightly. Guessing I'd have to put cvd's on the front to get better steering. I have new tires ordered and some mismatched wheels also coming that I'll just paint to make them match. Quick picture I snapped.
[/url]Untitled by Don Steuck, on Flickr
nitrostarter likes this.
lilws6 is offline
Old 07-29-2017, 10:00 AM
  #1515
Raman's Avatar
Rebuilt my TT02S with the white hardened chassis last night. Looking forward to see how much handling improves on carpet.
Raman is offline
