Front Arm sweep
Old 02-04-2013, 05:00 AM
Default Front Arm sweep
Hi All
Speaking to guys at the track we seem to have a little bit of confusion on front arm sweep. I think it takes a little initial steering away, but helps up the mid to exit steering. Others think it gives more overall steering. So I would be interested in hearing what others think?
Also what is an acceptable amount of sweep and what it too much? I know its kinda subjective, but on foams 1-1.5 deg seems good but on rubber I havent seen anything over 0.5 (Although I am talking about TRF's)
Also is it even worth using if you use a diff not a spool?
Cheers
Qatmix is offline
Old 02-04-2013, 08:46 AM
heretic's Avatar
I've never been able to describe what this adjustment feels like. I just know that every time I tried using some, the car felt better. On my photon I use 1.25 degree. I run mostly on carpet. Haven't tried increasing the angle more.
If I remember well the HB cyclone came with 2.5 degree out of the box. A few years ago. I was at a race and my cyclone had too much steering. I borrowed a 1-degree FF mount but it didn't seem to change the amount of steering, just a different feel. I went back to the 2.5.
Would definitely like to hear what others have to say about it.
heretic is offline
Old 02-04-2013, 09:34 AM
jlfx car audio's Avatar
Trader Rating: 37 (100%+)
In my own words , I feel it has less turn in at higher speeds but once weight has transferred it has more steering in mid/exit . Making car more lineior around the curve.
jlfx car audio is offline
Old 02-04-2013, 10:12 AM
racing_jason's Avatar
To me it always felt the car was more stable at higher speeds. Also the car had more steering in the middle of the corner.
Jason
racing_jason is offline
Old 02-05-2013, 02:32 AM
Mister-E's Avatar
+1
But also less turn in on slower speed.
To compensate the initial steering lost, I use anti dive where on the 417X, ff = 0 and fr = 0.5. The blocks used are: C at ff and B fr
Makes the car is easy to drive and control
Mister-E is offline
