Old 04-21-2005, 11:33 AM   #1
Trader Rating: 39 (100%+)
Send a message via AIM to Zac R Send a message via MSN to Zac R
Lightbulb turbo dyno
does any no how to set up a turbo dyno
and does anyone how many volts,amp and that other stuff shuold be set at
thanks
92zero Designs - AKA - O.S Engines - Futaba - Team Orion - B-Fast R/C LiveRC.com - RC Scoring Pro - TFR
92zero Deisgns
Decals - Clothing - Pit boards - Wraps - Signs - Banners & More
Zac R is offline   Reply With Quote
Old 04-21-2005, 11:55 AM   #2
ottoman's Avatar
R/C Tech Charter Subscriber
Dude... work on your spelling.... but if your looking for info on setting up your Turbo Dyno PM me.
Its real hard to figure out what your asking from this "does any no have to set up the tubo dyno"
ottoman is offline   Reply With Quote
Old 04-21-2005, 01:59 PM   #3
Company Representative
Tres's Avatar
Trader Rating: 14 (100%+)
Also dig through this thread, it has some good info...
http://www.rccars.com/forums/showthread.php?threadid=9
Tre's
TnT-Fx Custom Graphics
www.tnt-fx.com
Tres is offline   Reply With Quote
Old 04-21-2005, 02:30 PM   #4
EddieO's Avatar
I use the following settings
for stock and 19t.....
7 volts for 6 cell motors, 5 volts for 4 cell motors
Use amp steps....
Step 1 18 Amps
Step 2 20 Amps
Step 3 22 Amps
Step 4 25 Amps
Step 5 28 Amps
Step 6 30 Amps
For modified...
6 volts for 10 turn and above, 5 volts for 9 turn and below (use should really only use this to set efficiency)
Step 1 20 Amps
Step 2 25 Amps
Step 3 30 Amps
Step 4 35 Amps
Step 5 40 Amps
Step 6 45 Amps
Never use torque steps.....
Later EddieO
www.teambrood.com
EddieO is offline   Reply With Quote
Old 04-27-2005, 09:43 AM   #5
anyone else?
92zero Deisgns
Old 04-27-2005, 09:51 AM   #6
raving-monkey's Avatar
Send a message via MSN to raving-monkey
if i was you..i'd take Eddie's advice
his motors are ballistic...it would take a lot of work to get me to change mod motors
raving-monkey is offline   Reply With Quote
Old 04-27-2005, 10:18 AM   #7
mtveten's Avatar
Trader Rating: 27 (100%+)
Go with the steps Eddie provided, there is a reason why everyone uses the same testing profile.
Mark
mtveten is offline   Reply With Quote
Old 04-27-2005, 10:31 AM   #8
dgullickson's Avatar
Trader Rating: 45 (96%+)
Send a message via AIM to dgullickson Send a message via Yahoo to dgullickson
set it to 7 volts (for 6 cells) 5 volts (for 4 cells) make sure it is set to test in amps and we use the following steps:
Step 1 - 15
Step 2 - 17.5
Step 3 - 20
Step 4 - 22.5
Step 5 - 25
Step 6 - 28
Pretty close to what Eddie uses. Either is good just stick to one setting. Some tuners use the Torque setting which makes your Wattage number look higher than what it would be by testing in an Amp setting. To me this is playing the number game and doesnt give you true numbers and basically is used to give you the customer the impression that their motors are better. Dont be fooled by this. If you want I can scan a dyno sheet so you can see a typical amp load reading on a CE Turbo Dyno 45.
dgullickson is offline   Reply With Quote
CE TURBO DYNO 45 RCDEMON1 R/C Items: For Sale/Trade 0 02-06-2007 04:26 PM
CE Turbo Dyno 45 Amp boggszx7r R/C Items: For Sale/Trade 9 02-15-2006 02:23 PM
Turbo Dyno 45 and Turbo Matcher 4/30 Jeff Ford R/C Items: For Sale/Trade 5 11-14-2005 06:24 PM
Turbo Dyno or Robotronics Dyno picco007 R/C Items: Wanted to Buy 8 05-02-2005 12:48 PM
Turbo 45 Dyno jason cheng R/C Items: Wanted to Buy 1 05-04-2002 02:03 PM
