Old 01-26-2013, 07:25 PM   #1
Trader Rating: 42 (100%+)
Default Parma GoodTime Hemi coupe
I am looking for some info on this car. I know its old, but hoping to find out if there are other gears I can get. It has a fairly large spur gear that works with a slipper and acts as a diff. Wanted to know if I can get different sized spurs? Any ideas or suggestions would be great.
Drives a bunch of junk and has fun with it!
heljian is offline   Reply With Quote
Old 01-27-2013, 08:03 AM   #2
The spur gear used is the normal industry standard type that's used in almost all on road cars. get a 48 pitch spur gear with the same number of teeth as the one you have, it should have the number somewhere on the gear. My personal favourites are the HPI Racing 48 pitch carbon reinforced spurs.
The balls and washers aren't a "slipper that acts as a diff", it is the diff and the adjuster nut should be tightened just enough so the diff doesn't slip at all.
terry.sc is offline   Reply With Quote
Old 01-27-2013, 01:37 PM   #3
Default Thanks
Thanks for the info!
