-   -   lrp cpx 30 to ride 32 (https://www.rctech.net/forum/electric-road/698497-lrp-cpx-30-ride-32-a.html)
daang 01-24-2013 08:57 AM
When I change the tyres from cpx 30 to ride 32, the car gets higher.
What I need to do with my downstops?
For example, front is 6mm downstops, does it need to be increased like 7mm, or decreased like 5mm?
When I change the tyres without changing downstops the car isnt very directive anymore and response is slow.
cyclonetog 01-24-2013 10:34 AM
You need to adjust the downstop to a higher number by the same amount that the ride height changed.
e.g. ride height changes 5mm --> 5.5mm
downstop change form 6mm --> 6.5mm
Then you change the ride height back to what it was.
The thing is that a different tyre is more than likely to need a different setup anyway so it's not all that important really.
