Old 04-19-2005, 06:03 PM   #1
tc3blue's Avatar
Default ICE charge rate
i initially posted this in the duratrax ICE forum, but nobody seems to be browsing it and i will go racing soon, so i'm interested in this please:
i just got this charger(duratrax ICE) today and i was interested in how you guys charger 3300MAH and 3600 MAH batteries.
i see there are a lot of options...
i just tried the normal mode using the 3600 MAH and 5.0A and when it stopped charging it showed 2900MAH, is it not supposed to show 3600MAH or am i doing this wrong.(or could the battery just be too used, even though it wasn't bought too long ago)
sorry for this question...i just had a cheap charger before where all i had to do was press a button...so i'm not used to this
thanks!
tc3blue is offline   Reply With Quote
Old 04-19-2005, 06:05 PM   #2
I hate to say it, but the 3600s are terrible... You may have worn them down already... My distributors aren't even selling them anymore...
elmo6s is offline   Reply With Quote
Old 04-19-2005, 06:18 PM   #3
tc3blue's Avatar
hmm i don't think the sanyo 3600mah are terrible....
well anyways to get back to my initial question...anyone??
Old 04-19-2005, 06:22 PM   #4
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Try cycling the packs a few times and also use a tray discharger everytime to equalise each single cell.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 04-19-2005, 06:30 PM   #5
polesitter61's Avatar
Check the peak sensitivity, should be between 3 to 5 mv. If not the pack may false peak. I have one and it works great. After traying my ProMatch 3300's down to .9 per cell I'll get anywhere from 3450 to 3550 mah into them.
Slickzero R/C products, check them out, very cheap shipping!!!
www.slickzero.com
polesitter61 is offline   Reply With Quote
Old 04-19-2005, 07:25 PM   #6
Claydoh's Avatar
Send a message via AIM to Claydoh
yeah, if the pack wasn't dead, you can't cram 3600 into them. 6amps at 5mv is fine. make sure and disable trickle.
Claydoh is offline   Reply With Quote
Old 04-19-2005, 09:50 PM   #7
schmelme's Avatar
probably just cells that are bad or need some attention. Most good 3300's should at least take 3800mah at 6.5amps
schmelme is offline   Reply With Quote
Old 04-20-2005, 02:15 PM   #8
Sometimes a 3300 cell with a High IR will show big Mah numbers on the charger, that does not mean you got 3800mah into them, either that or you are charging from a much lower voltage to begin with. I start at 5.4 (.9 per cell on the tray) and then start charging.
www.slickzero.com
Charge rate questions jimmie48fromRI Electric Off-Road 5 04-13-2007 04:17 PM
Charge rate question? jimmie48fromRI R/C Tech Site Forum 1 04-13-2007 03:13 PM
Hara's charge rate? josh69162 Electric On-Road 31 08-04-2005 08:21 PM
charge rate measurements The_Gaz Electric On-Road 1 06-10-2004 01:32 AM
charge rate/time nitrosaurus Rookie Zone 10 12-25-2003 11:56 PM
