Old 04-17-2005, 04:24 AM   #1
Default What updates / hop-ups for Pro4?
Bought a HPI Pro4 when it was first released. Built it, and had plans to start 1/10 electric racing but never did. I'm going to start taking it to the track and wanted to know what updates do I need? I remember hearing of several updates HPI had done to their kits, but don't want to dig through the huge Pro4 thread. Also, what hop-ups are recomended?
Thanks.
VictionOne is offline   Reply With Quote
Old 04-17-2005, 07:32 AM   #2
Trader Rating: 17 (100%+)
bewel gear v1.1
Tamiya TB Evo 5
Spektrum DX3R 2.4Ghz, Sanwa ERG-VX, VFS-1
EngTat is offline   Reply With Quote
Old 04-17-2005, 07:34 AM   #3
the kit you bought is oledr newer kit which 1.1 just added new bewel gear and brace i think pro 4 just release another pro4 which is pro4 2005
Tamiya TB Evo 5
Old 04-17-2005, 08:16 AM   #4
Exe
Exe's Avatar
Send a message via ICQ to Exe Send a message via Yahoo to Exe
ae diff thrust t-nut, titanium or steel front bones. these are a must.
Exe is offline   Reply With Quote
Old 04-17-2005, 01:03 PM   #5
Anyone know the part numbers for the 1.1 bevel gear upgrade and brace? And what is the brace?
I saw a diagram on how to convert to the AE diff nut. Where can I find this diagram?
Also, who makes Ti bones for the Pro4?
Old 04-17-2005, 01:14 PM   #6
Exe
Exe's Avatar
you don't need any diagram, you just buy this http://www2.towerhobbies.com/cgi-bin...?&I=LX2869&P=7 and use is instead of original hpi pro4 bolt and nut, everything else not needed. no cutting required, nothing.
titanium bones Square Titanium CVD Drive Shafts for HPI Pro 4 or Associated TC3 #SHP50C
you can buy at www.precisionrc.com 45$ two bones, they won't bend. i changed to full titanium universals, i mean i changes shafts, bones and joints. cause when you roll with your car, metal shafts simply bend and you wheels start kinf of shaking and giving big vibration
HPI Bevel Gear Set (39T/16T/Spacer) - Ver 1.1 for Pro4 #73501
4$ you can also buy at precisionrc.com
cheers,
Old 04-17-2005, 01:25 PM   #7
RCGaryK's Avatar
If you run on Carpet, the 3mm chassis is dialed. Also, pick up a Buds TC3 bumper, it will save you breakage later on. Also grab the swaybar set, and a set of suspension mount shims. I also put the 6mm wheel hexes so I didn't have to use the washers...on some of the Takeoff Rims I used, the washers pushed the wheel a bit far out and the molded hex could get stripped or damaged in a wreck.
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 04-18-2005, 01:41 AM   #8
thanks for the replies. Received a lot more info than I expected.
Old 04-18-2005, 02:28 AM   #9
RC Driver Gary, where did you find the 6mm wheel hexes? square? hpi? can you give me the part number?
i noticed the other day, that the stock Rear Input Shaft had bent, for no obvious reason (no crashes). i guess i'll have to change to the square titanium one. speedtechrc are the cheapest online square distributor i know, but they're usually out of stock!
i don't like the fact that the team drivers don't race the pro4 anymore. they all seem to have changed to the cyclone.
billtc3 is offline   Reply With Quote
Old 04-18-2005, 09:55 PM   #10
RCGaryK's Avatar
HPI Part Number 33407
HorizonHobby.Com
Old 04-18-2005, 11:59 PM   #11
loopedeloop's Avatar
This is a worry........WHY IS THIS????
loopedeloop is offline   Reply With Quote
Old 04-20-2005, 02:46 AM   #12
thanks for the part number gary
loopedeloop, the question is to "hup-up or not to hop-up" ? i dont' want to spend money on a car that could be discontinued in a couple of months
Old 04-20-2005, 04:03 AM   #13
Exe
Exe's Avatar
there is no way hpi will do this. cyclone it's just a marketing trick to earn more money! some choose cyclone, some will stick to pro4, hpi released two different cars to attrac more people who will buy cyclone either pro4.
same goes to different companies like procter and gamble, who produce different washing powder at different price levels and advertise them as different products, to make artificial competition, but money goes to the same producer.
same here cyclone and pro4. hpi will never drop pro4 unless pro5 appears and these two cars will be developing separately.
2 cents
Old 04-20-2005, 08:29 AM   #14
Exe, it's good to hear that.
Yokomo did well in the 2005 Super Stock Championships at Yatabe Arena, half of the drives driving the SDW and the rest the BD. The hpi drivers though, race the cyclone only.
anyway, the pro4 and the cyclone share the same suspension parts, so if the former was discontinued, it should still be easy to replace broken parts.
Old 04-21-2005, 03:08 AM   #15
GRF
GRF's Avatar
Default Re: What updates / hop-ups for Pro4?
Thanks.
Basically, most of the hop-ups of the Pro 4 are incorporated in the 2005 edition...
GRF is offline   Reply With Quote
More Updates! Platinum_Racing Web Links 4 01-09-2006 09:36 PM
BMI Pro4 + HPI Pro4 Plus tons of spare Parts Sluggo R/C Items: For Sale/Trade 13 11-01-2005 04:37 PM
