Old 01-10-2013, 12:07 AM   #1
Default Trinity D3.5 !7.5 ?!?!
Hey guys I just installed a brand new Trinity D3.5 17.5 turn motor in my touring car along with a brand new ESC (Tekin RS)
I am in the middle of doing my initial setup and what not .....But I am getting this weird noise out of the motor almost like a grinding sound ?
Not sure what it could be ....It seem to happen when hittin the brake or if you punch the throttle hard or just feathering the throttle from a complete stop .....All of this has been on the bench I have not ran the car yet as I am still setting it all up . My gear mesh is fine I also took the spur gear out and did the same tests to see if the motor would make that sound and sure enough it was still there.
I am a little new too this and just want a clarification on if this is normal does it need to break in or do I have an issue .....I just heard the noise and it just doesnt seem right .
Let me know what you guys think.
Will,
yunowill is offline   Reply With Quote
Old 01-10-2013, 01:26 AM   #2
Trader Rating: 20 (100%+)
Will,
try backing off from the timing if you added any and see if it still happens
goots is offline   Reply With Quote
Old 01-10-2013, 02:22 AM   #3
defcone's Avatar
Trader Rating: 15 (100%+)
Sensor cable/and or sensor in motor/esc.
defcone is offline   Reply With Quote
Old 01-10-2013, 08:39 AM   #4
2xs
ESC/Motor wires in the correct order? A-A,B-B and C-C.
2xs is offline   Reply With Quote
Old 01-10-2013, 08:48 AM   #5
JFuel11's Avatar
Trader Rating: 152 (100%+)
Default Double Check Wires and Sensor Cable
Is the motor run ok other than the noise?
Most likely you have it wired in-correct.... I am a 20+ year racer and still swap a wire by accedent every now and then... Makes the same grind or grunt type noise and will not run or harldy run.
If everything checks out and it is still making the grinding noise and the motor runs as it should but only makes noise, remove motor and examine drive-tran and motor, include break motor down and examine internal to make sure all is correct.
If motor is wired correclty it could be the rotor is not spaced correclty inside the motor and is touching our grinding on the sensor ring. Easy fix, just reshim the rotor about 1mm away from sensors if this is the problem.
Let us know if you need more help!
Alan Bachman (AKA - Johnny Rocket Fuel)
Help your fellow racers go faster... You will have more competition!!!
Sponsors:
RC America - XRay - Hudy - Maclan Racing - Xpert Servos - Schelle Racing Innovations - AKA Racing Products - DE Racing - Sticky Kicks - Sanwa
JFuel11 is offline   Reply With Quote
Old 01-10-2013, 02:12 PM   #6
Okay I checked all my wiring and everything seems to be perfect in terms of all the terminals . This whole sensored thing is alittle new to me and I forgot to add to my original post that the motor was making this or these noises WITHOUT the sensor wire connected . However reason being that it was not connected was that when it was connected it instantly got hot as soon as the ESC was turned on so I unplugged it right away .
The speed controller still works without it connected and is still functioning throughout the modes and what not so I know it didnt fry the ESC ...It was not even plugged in long enough for it to do damage and being that it still works .... I am not sure what this issue could be or what to look at next .
Old 01-10-2013, 02:19 PM   #7
gearhead_22's Avatar
Send a message via AIM to gearhead_22
how long are your motor mounting screws
serpent sdx4 srx2 977WC-novarossi-748TQ
serpent S120 LTR-S411
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter
gearhead_22 is offline   Reply With Quote
Old 01-10-2013, 02:22 PM   #8
but if you motor is getting hot like that with the sensor pluged in the you must have a bad motor. call trinty and let them know what is going on and I am sure they will take care of you.
Juwan Hunter
Old 01-18-2013, 12:35 PM   #9
rcsuicide's Avatar
FYI. Trinity D3.5 17.5 motors are no longer ROAR legal. You can read the news release here --> http://www.roarracing.com/?cat=6
Originally Posted by ROAR Approvals View Post
Approval status of Trinity D3.5 and D3.5-based OEM motors
Thursday, January 17th, 2013
After a great deal of consideration the ROAR Executive Committee has determined that the Trinity D3.5 motor and others based on the D3.5, do not comply with the organizationís required specifications for motors in the 17.5 stock class. The determination is based on the fact that motors being sold are built with wire thatís larger than maximum specification permitted. All of the random samples of the D3.5 based motors during the announced compliance checks tested with wire thatís larger than the maximum dimension. Rule 8.8.4.3.1 states clearly that ďThe three slotted stator must be wound with 17.5 turns of 2 strands of a maximum diameter of 20AWG or 0.813 mm per slot. A diameter of .813mm is the nominal measurement of 20AWG wire, and that it is the stated maximum wire diameter permitted. Itís on this basis that the Executive Committee made its determination.
rcsuicide is offline   Reply With Quote
Old 01-18-2013, 12:39 PM   #10
rcsuicide's Avatar
You can read the official ROAR news release here --> http://www.roarracing.com/?cat=6
After a great deal of consideration the ROAR Executive Committee has determined that the Trinity D3.5 motor and others based on the D3.5, do not comply with the organization’s required specifications for motors in the 17.5 stock class. The determination is based on the fact that motors being sold are built with wire that’s larger than maximum specification permitted. All of the random samples of the D3.5 based motors during the announced compliance checks tested with wire that’s larger than the maximum dimension. Rule 8.8.4.3.1 states clearly that “The three slotted stator must be wound with 17.5 turns of 2 strands of a maximum diameter of 20AWG or 0.813 mm per slot. A diameter of .813mm is the nominal measurement of 20AWG wire, and that it is the stated maximum wire diameter permitted. It’s on this basis that the Executive Committee made its determination.
Old 01-18-2013, 12:42 PM   #11
rcsuicide's Avatar
Old 01-18-2013, 12:43 PM   #12
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
Or you can read it and the 13+ page soap opera that followed here: http://www.rctech.net/forum/electric...-5-17-5-a.html
trackdesigner71 is offline   Reply With Quote
Old 01-18-2013, 01:07 PM   #13
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Make 100% sure your motor A B C wires are in the correct order.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 01-18-2013, 01:11 PM   #14
Suspended
GET YOUR MONEY BACK OR EXCHANGE YOUR MOTOR WITH ANOTHER BRAND ASAP, BECAUSE THE 17.5T D3.5 MOTOR IS ILLEGAL !!!!!
bertrandsv87 is offline   Reply With Quote
Old 01-18-2013, 01:21 PM   #15
If your positive all the wires are in the right place then it is likely you have a bad solder joint somewhere. I've had motors act strange in the past and everything looked fine. Re-soldered all the connections and it started working fine.
for sale mmp esc/trinity d3.5 17.5 motor new mylaps transponder sc10rs pre roller rcaddiction R/C Items: For Sale/Trade 12 09-11-2012 05:03 PM
Revtech, Trinity D3, LRP X12 motors xrayaustin R/C Items: For Sale/Trade 8 08-06-2012 10:43 AM
Airtronics Radio, Spektrum Pro, Trinity D3 10.5, Kyosho Springs Jake S R/C Items: For Sale/Trade 22 02-02-2012 11:44 PM
