Old 01-07-2013, 03:16 PM   #1
Default Sprint 2 Drift RC Issue
I've had my R/C since christmas I've ran it for about 2-3 hours in total ever since. Last night I was running it and a random knocking noise started it sounds like it's around the spur gear/engine. I'm not sure exactly what it could be any advice? It's a Sprint 2 Drift 350z came straight out of the box. No mods at all.
Bugatti3393 is offline   Reply With Quote
Old 01-07-2013, 05:16 PM   #2
Marv's Avatar
Get the manual out and start checking all the screws / make sure they are present and tight.
This includes the spur gear screws and the pinion set screw.
Make sure the motor mounting screws are tight.
The screws that hold the motor mounts to the bulk heads in the rear are notorious for coming loose and falling out.
Check the teeth on the rear belt/rear belt pulley/rear diff to see if you picked up a small pebble...
Marv is offline   Reply With Quote
Old 01-07-2013, 05:35 PM   #3
Alright, Thank youu =)
Old 01-07-2013, 05:41 PM   #4
Marv's Avatar
Thumbs up
You might find some useful info here - http://www.rctech.net/forum/electric...-sows-ear.html
Old 01-07-2013, 06:33 PM   #5
x10 on the rear screws, mine didn't even come with them factory.
2013 HPI Mini Recon
2012 HPI Sprint 2 Sport
1983 Marui Samurai
Slobalt7 is offline   Reply With Quote
Drifting using Counter-steer, overdrive, 4WD, front one-way jiewei1987 Electric On-Road 8 10-26-2017 07:01 AM
HSP RTR's on ebay. need advice. for first rc car. dethRC Rookie Zone 28 12-29-2009 04:18 PM
