Like Tree47Likes
Tamiya XV-01
Old 02-28-2018, 12:53 AM
  #1711
Originally Posted by jmracer86 View Post
What are you guys running for brushless motors and esc's that's waterproof? I am currently running a Novak edge 2s esc with an Orca TX 17.5 brushless sensored motor but would like to upgrade to something I can play with in the rain and snow. I don't want to go brushed and keep the power similar to a 17.5 motor or even a 13.5. Bonus if it fits in the electronics box as I like to keep my builds tidy.
I am planning to convert my brushed setup to a Hobbywing ezrun max10 combo with a 3300kv setup when my funds allow it.
http://hobbywing.com/goods.php?id=57....0.0.0.0.0.0.0
If you are using an esc with a fan you might have to remove one of the electronics section covers. Since the stuff is waterproof, it shouldn't matter.
ejtnt is offline
Old 02-28-2018, 11:27 AM
  #1712
Raman's Avatar
Trader Rating: 59 (100%+)
Originally Posted by ejtnt View Post
I think you have some info wrong there. According to the hobbywing website this is not the case.
QuicRun 10BL60/120 Sensored_Car Systems_HOBBYWING | Welcome to Brushless System Trends -
I’m going off their site as well..
See here:
https://www.hobbywingdirect.com/collections/quicrun-brushless-system
Features
Water-proof and dust-proof for all-weather races.
Want to drive during tough weather like pro racers? With our QucRUN brushless series, you no longer need a traditional waterproofing box. Our ESC is completely waterproofed so that you can save not only space in a compartment but also the weight of the vehicle.
Now if that particular model is not waterproof.. then that’s false advertising on their part
Raman is offline
Old 02-28-2018, 11:28 AM
  #1713
Raman's Avatar
This is from the product page
Dust-proof for all-weather races.
1/10 & 1/12 On-road / Off-road / F1 / Drift car race
Street race for fun / Club racing / STOCK race with 0 timing / Drift car race
https://www.hobbywingdirect.com/products/quicrun-10-sensored?variant=710246737
Raman is offline
Old 03-01-2018, 01:20 AM
  #1714
See here:
https://www.hobbywingdirect.com/coll...ushless-system
Features
Sorry my mistake. There are two different products with similar names which what had me confused. The naming on the website where your links come from is not exactly the same with the naming from the website I am posting from.
There are two models:
10BL60 SD / 10BL60 Sensored --> Not waterproof
10BL60 / WP 10BL60 --> Waterproof
Point is, Hobbywing makes very nice products, and the waterproof stuff, has been really waterproof for me. As in, I have fully submerged stuff and they kept working without issues.
ejtnt is offline
Old 03-01-2018, 05:38 AM
  #1715
fyrstormer's Avatar
Has anyone ever found additional bodies that fit with zero front overhang, like the Lancia Delta body does? Occasionally I think it would be nice to have a different rally car body (maybe one with real headlight buckets), but I want to be able to run the hard front bumper from the XV-01T, and the Lancia Delta body is the only body I know will fit behind the hard bumper.
fyrstormer is offline
Old 03-02-2018, 01:57 AM
  #1716
I am not entirely sure what you mean with zero overhang, but I had a killerbody Evo X that was a very snug fit. There was no gap between the body and the fron bumper. I think the Tamiya Evo X is similar in dimensions but since I have seen you have had that body on your DF-03, should I assume it does not clear the bumper?
ejtnt is offline
Old 03-02-2018, 04:21 AM
  #1717
fyrstormer's Avatar
What I'm looking for is a body that fits correctly without any foam bumper at all.
Old 03-02-2018, 05:15 AM
  #1718
Ok I see your point. I have no concrete answers but I think it would be interesting to investigate some of the bodies that came with the FF chassis. The FF-02 in particular seems to have the shortest front bumper. The Castrol Honda Civic(51421) and the VW scirroco look like potential candidates. Potentially the Suzuki SX4, VW golf gti (51339) and Honda CR Z could also look like candidates.
The older VW golfs (V5 and VR6) would probably be even closer, but they are a bit harder to find and a bit pricy.
ejtnt is offline
Old 03-13-2018, 10:14 AM
  #1719
I have been considering buying all the necessary parts to convert my XV-01 pro to a pro TC, but it looks like the cost is a lot higher than what I expected. As a matter of fact it is so high that I would rather have a second XV-01 in the tc version, but I cannot seem to find any available everywhere I look.
If you are interested in selling one, just give me a PM.
ejtnt is offline
Old 03-13-2018, 02:23 PM
  #1720
Location: El Pueblo de Nuestra Señora La Reina de Los Ángeles del Río de Porciúncula, California, Unites States of America
Trader Rating: 36 (100%+)
haven't had a chance to run my XV01 but am wondering, does the front motor weight bias help for rally/loose surfaces? how would a TC work in loose surfaces with its more balanced setup?
lagcisco is offline
Old 03-13-2018, 09:26 PM
  #1721
The xv-01 tends to be a little more tail happy. Pivoting from the nose. Where a TC car with a center mount motor will rotate around its center. It's not as obvious on the street unless you are doing slalom or driving on dusty streets with bad tires.
lagcisco likes this.
4roller is offline
Old 03-14-2018, 12:28 AM
  #1722
Modified TC works better for rally racing. XV-01 is more fun for rally bashing ;-)
haplm is offline
Old 03-16-2018, 09:34 AM
  #1723
Anyone using the TA BB 12mm springs?
If there is, what is the length of the rear & front springs?
airbiscuit is online now
Old 03-16-2018, 02:39 PM
  #1724
Yes, I do, the shorter ones (44 or 45mm). The longer ones are too long even for my already-quite-long 85mm TA shocks.
haplm is offline
Old 03-16-2018, 06:19 PM
  #1725
So I believe the shorter ones are the front spring sets right?
And yes, what is the differences between 1 way set & the spool? I know there is a 1 way set for the xv. The TA06 for example, got both.
