Old 01-03-2013, 10:56 AM   #1
looper's Avatar
Trader Rating: 19 (100%+)
Send a message via Yahoo to looper
Default question for those who ran 27x1 brushed
what fdr did you aim for when running 1/10th onroad 27x1?
Clarification: 4wd touring car
Looped Designs Paintwerks
http://ldpaint.webs.com/ Email: [email protected]
looper is offline   Reply With Quote
Old 01-03-2013, 11:08 AM   #2
Trader Rating: 88 (100%+)
Much as it does today it depends on the motor. I remember being able to gear a P2K2 down to a low 6 and but a Green Machine 3 would burn at that same ratio so had to be run in the 7's.
Shane W.
Everything for Sale - out of hobby
tcdrvr2 is offline   Reply With Quote
Old 01-03-2013, 11:11 AM   #3
There were so many variables, it depended on the track layout and which motor you used as some revved higher while others had more torque and could be geared up. Even which brushes and springs you were running made a difference.
terry.sc is offline   Reply With Quote
Old 01-03-2013, 11:11 AM   #4
Fuzzi0n's Avatar
Sounds about right, I think I used to aim around 6.5 as a starting point.
Spec-R S1, Schumacher CAT SX3 S1
Fuzzi0n is offline   Reply With Quote
Old 01-03-2013, 11:20 AM   #5
looper's Avatar
Thanks for the replies guys!
I took mine out yesterday geared at 4.3 and it was wrong. the motor i am using is a birdman (see pic) i didnt want to go buying a boatload of pinions trying to find the right gearing. the track i am running on is a long one (former go cart track like the ones you find at mini golf places) traction would be considered poor.
So instead of running a 100s and 40p i should run a 26 instead
http://www.arroyoc.com/index.cfm?fus...=Gear&Plot=mid
Old 01-03-2013, 02:08 PM   #6
Suspended
It also depends on whether the motor was zapped or not , but in general 6.3fdr to 7.2fdr is where you want to be... A zapped 27t stocker pulls alot harder while remaining cool....
bertrandsv87 is online now   Reply With Quote
Old 01-03-2013, 02:14 PM   #7
Suspended
I ran a zapped 27t trinity monster stock horsepower with lipos at 6.42fdr(small carpet track) versus the new 17.5t brushless motors, and the motor held its own, eventhough my setup and driving was not up to snuff ....
