SP Reventon Pro + SP 5.5T Brushless - HELP! >
Old 01-03-2013, 09:25 AM
Angry SP Reventon Pro + SP 5.5T Brushless - HELP!
hey people, i recently switched the polarity on my lipo by accident while plugged into the esc & now I'm facing some problems.. (obviously)
after the esc smoked up a little bit, i quickly disconnected the battery, waited for it to cool down & plugged it all back in properly to see if it was ok.
this is what has been happening since..
* while the sensor cable is plugged in, motor doesn't accelerate. tried turning it a bit with my fingers & motor started operating in reverse.
* removed sensor cable. motor accelerates normally in the proper direction. give it a rest & then you need to use your fingers to turn it just to get it started up again.
I don't have another motor to test & see if the esc is still ok or not but the motor i have hand turns quite freely so i don't see how that could be the issue.
is anyone able to shed some light on this & let me know if you have experienced the same problem if not something similar? many thanks!
Sakura87 is offline
Old 01-03-2013, 10:45 AM
Trader Rating: 14 (100%+)
Looks like you have released the magic smoke and the ESC is DOA. Motor is probably ok though. I doubt the warranty covers reverse polarity situations. I would contact your Speedpassion distributor for out of warranty repair or replacement.
thunderbt3 is offline
Old 01-03-2013, 11:13 AM
You don't need more than a sec to kill your esc with reverse polarity
Akita is offline
Old 01-03-2013, 11:33 AM
TAMAK's Avatar
Trader Rating: 29 (100%+)
The ESC is Done! Contact Speed Passion, they may get you in a refurbed one... Worth a shot.
TAMAK is offline
Old 01-03-2013, 03:48 PM
ta04evah's Avatar
Once the magic blue smoke is released.
https://www.youtube.com/watch?v=IM0a4HKZ-ps
Cheers
Rob.
ta04evah is offline
Old 01-03-2013, 04:36 PM
I will get right on to contacting them. What I don't understand is though, why would the ESC still be able to turn on with the according lights? I plugged it into the PC & it still picks it up perfect & i'm able to adjust everything & update the firmware along with being able to use the program card..
Sakura87 is offline
Old 01-03-2013, 05:56 PM
duckman996's Avatar
You probably blew a fet or cap inside... not a total loss but it will never work properly. Contact SP they might be able to fix it or replace it with a referb.
duckman996 is offline
Old 01-04-2013, 06:17 AM
I bought it from RC Mart so I'll be sending it back to them. Thanks anyway guys!
Sakura87 is offline
Old 01-04-2013, 10:32 AM
BigC123's Avatar
Speed Passion has an Australia store now I think.
BigC123 is offline
Old 01-04-2013, 05:45 PM
Yeah they have an Australian warehouse but don't do warranty repairs. Sucks but ahh well. Need to send it off & wait it out now man.
Sakura87 is offline
Old 01-04-2013, 06:22 PM
Your ESC have been damaged. Next time, try to use the other sensor cable if you have this issue. I suggest you to use a new sensor cable if you get back a new ESC.
WMGary is offline
Old 01-04-2013, 06:25 PM
Will do. Need to make sure that I eliminate all problems as I need to ESC to compete in races.
Sakura87 is offline
Old 08-16-2013, 03:28 AM
hI,
I have the same problem actually. I misplaced polarity of my battery. But not until i turn on, just until i plugged esc to batt, esc was still turned off..then after that i quicly change back polarity, when i turn esc on..nothing happen..i tried to connect to my pc, there is still connection, and still i can change setting. But motor won't run...anyone probably have any idea what was going on ?..thanks
3line is offline
Old 08-16-2013, 09:37 AM
Originally Posted by 3line
hI,
Yes. Your ESC is damaged and needs to be replaced/fixed.
JamesL_71 is offline
Old 02-25-2016, 03:52 AM
Questions?? Help were to send esc for repair?
Can any one help me speed passion Reventon 1.1EX just stopped working. I'v had it for a year or two so were do I send it for repair? I'm in the U.K. .
I'v don't all I can with it pc and wires and motor rx so just need to no were to send it.
Mogg is offline
