Old 04-13-2005, 11:11 PM   #46
PlainOleDave's Avatar
Trader Rating: 14 (100%+)
Ditto on which bit I got. One is simply carved/shaped and the other has a blackish plate mounted to the lower side. The blackish plate is chipped badly so I fingered it was bad but I don't know if I could reshape it or wut?
PlainOleDave is offline   Reply With Quote
Old 04-18-2005, 10:15 AM   #47
**BUMP**
Old 04-18-2005, 12:14 PM   #48
Pezz's Avatar
Send a message via Yahoo to Pezz
Being a machinist for 15 years, most of what I am reading here has nothing to do with whether the bit is sharp or dull. Lathes with dull bits will produce a nice finish if your feedrate, depth of cut, and rpms are correct. That's saying if the bit is dull, not chipped. I use high speed steel blanks and drill and tap for a circle brand carbide insert with Ticn coating and a .007 rad. It is a triangle shaped insert, so I get three sides to work with, the blank never leaves the lathe, just the insert when it is used up, and I can say that one insert should last about six months if used properly, then I just grab another insert (3.00) and start again. Copper is very soft, and requires feather light cuts with the right rpms to produce a good finish. Never ever back the bit accross the com after you have made the final cut.
Pezz is offline   Reply With Quote
Old 04-18-2005, 03:48 PM   #49
protc3's Avatar
dude,a dull bit on copper will burnish the surface and create a pitting effect.there is more to it than just speed and feed.i am also a machinist of 16 years.cutting .001 per pass you need a razor sharp bit with a real small tool nose radius.carbide inserts would work if you have a small enough tool nose radius.you really cant compare to what we do in the shop because comm lathes do not brace the armature well.i attempted using a mini tool holder with a very small insert and it didnt do the job very well.smallest radius i could find was .007.plus the cost of carbide inserts makes it not worth it.i get much more life out of a cemented carbide.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 04-18-2005, 04:06 PM   #50
how can I visual tell if my diamond bit on my lathe needs to be resharpened?
cheerz
Obsidian is offline   Reply With Quote
Old 04-18-2005, 05:54 PM   #51
PitCrew's Avatar
I have found that my lathe cuts much nicer when I only use 2-2.5 volts from the Pulsar. At aroudn 4 like a 4 cell pack, its not as nice.
I think this is probably better for carbide than diamond because it creates a larger chip, which takes away the heat, instead of just friction. You would be surprised to know how much friction is happening at higher RPM at the feed rate we use on these lathes. Its a fairly slow feed rate, so its not making a chip, therefore its not cutting.
I get a BEUTIFUL finish at 2-2.5 volts taking off .0005 per cut using a pace of aboukt 2-3 seconds to feed the entire length of comm.
PitCrew is offline   Reply With Quote
Old 04-18-2005, 05:54 PM   #52
protc3's Avatar
you can look at it with a jewelers eye loop.you should be able to see if there are any chips in the cutting surface.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 04-18-2005, 06:36 PM   #53
Pezz's Avatar
I would agree you can burnish copper very easy, but you can also make a good cut as well, I never have any problems at the track or at work. In any regrads I guess it will be up to the individual as to how well they can turn a comm.
Motor/Speed Control Issue? BCrumB4 Radio and Electronics 2 04-15-2008 12:51 PM
motor issue vthenry07 Rookie Zone 4 06-24-2007 09:58 AM
Gold Coast Comm Truing Haydo Australian Racing 1 06-18-2007 02:53 AM
WTB Tire Truing Machine and Motor Lathe gunlocators R/C Items: Wanted to Buy 3 03-18-2007 09:47 PM
Motor Truing nerdling Australian Racing 2 08-24-2003 08:00 PM
