Old 02-09-2013, 11:12 AM   #316
Pull rod suspension! Nice...I thought it might be that from the early pics. Do the ball studs slide in the lever arm or is there a small link in there that we can't see?
For caster are you going to make different c-hubs at pre-set angles?
Edit: Now that I'm looking at it on my desktop instead of my tablet I can see the pics more clearly and see where the ball stud will slide in the cantilever
Old 02-09-2013, 11:28 AM   #317
heretic's Avatar
Originally Posted by protc3 View Post
I am also going to be adding new holes on the arms where the up travel screw and ballstud mount. I am going to allow for them to be swapped for location. This will allow you to adjust leverage points. The further the ballstud is from the pivot of the cantilever, the softer the spring rate. This way you will have 2 spring rate options per set of springs with that now being 6 spring rates instead of 3.
If you could add shims under the ballstud on the a-arms, wouldn't that also make the spring effect harder ? You would then just need to shim the pivoting part accordingly toward the center of the car, or maybe even not. I guess with such a short lever, adding 0,5 mm or 1mm under the ball stud would significantly make the spring effect harder. Anyway, super cool front end. It was about time someone released a front end with double a-arms and real dampening on a pan-car ( the exception being the recent yokomo, but I'm not sure of how the monoshock works exactly).
I love wedge bodies. I love dish wheels.
heretic is offline   Reply With Quote
Old 02-09-2013, 11:48 AM   #318
protc3's Avatar
It is a sliding pivot ball. Caster will be changed via c hub.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 02-09-2013, 11:51 AM   #319
protc3's Avatar
There isnt much room to shim the ballstud but we do use the medium length ballstuds to increase spring rate. Your thinking is correct. The difference between a standard and medium ballstud is quite different.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 02-09-2013, 05:24 PM   #320
Jason, this new car looks awesome so far!! Love the pull-rod front suspension!!
You should do an F1 car version of this car next...I bet it would be awesome!!
Team Lotus is offline   Reply With Quote
Old 02-09-2013, 05:44 PM   #321
jeff jenkins's Avatar
Trader Rating: 77 (100%+)
An f1 would be sick. I'm not going to lie , when I saw the front end pics this morning I went from 6 to midnight.....
Maclan Racing Products-Bellgate Distributions-PR Racing- Prospeed
jeff jenkins is offline   Reply With Quote
Old 02-09-2013, 05:51 PM   #322
protc3's Avatar
Once i get things rolling, i will see what i can come up with for an F1.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 02-09-2013, 11:06 PM   #323
EricF's Avatar
OOOOOOOOO!!! Yeahaeh!
E
AE 12R5.2 & R6(x2) - TC7.1 convert, F6 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
Old 02-09-2013, 11:50 PM   #324
can I have one yet? I have seen more than enough.
I am impatient , me wantee me wantee
I pay to play, do you ?
ozace is offline   Reply With Quote
Old 02-10-2013, 01:24 AM   #325
Radio Active's Avatar
Congratulations Jason on what is a genuine innovation for the class.
I'm not a BMI driver* but I'm sure this car will generate some interest. The guys who run the 12R in Australia are pretty passionate about the marque. And I think here your car has even more potential than perhaps in the US or the UK because we race on tarmac and rough finished concrete (as well as carpet) on unprepared surfaces. Basically, tracks can be rough, and grip low and this is where the level of adjustment and improved damping at the front can be a significant advantage.
* I actually have a 12th design project of my own.
Reigning NSW 4WD Group 20 Champion
Member: Maitland Radio Car Club (http://www.morcc.com.au)
twitter: @dvcotton
Australian 12th Scale hastag: #EP12AU
Radio Active is offline   Reply With Quote
Old 02-10-2013, 02:44 AM   #326
howardcano's Avatar
Trader Rating: 35 (100%+)
Hi Jason,
Which Losi spring will give the equivalent spring rate to a "normal" front suspension using 0.020" springs? Those Micro-T springs are pretty soft, and it looks like there is quite a bit of leverage on the spring, too. Or are you using your own springs?
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 02-10-2013, 03:34 AM   #327
He is making his own shocks and springs
Old 02-10-2013, 04:38 AM   #328
protc3's Avatar
Thanks buddy. I am looking to improve overall performance on all surfaces. The benefit of a good double wishbone should give me that once i get everything situated. So much goes on in a strut front end as it moves. I am looking to increase corner speed, give more adjustment for all surfaces, and make the car just overall easier to set up. I am going to spend time figuring the baseline setup but it should work real well. The big handling improvements are going to be generated by pretty close to perfect steering geometry. There is going to be close to no scrub at all through out the full steering throw. This is something that just isnt an available option today.
Im ok with the fact that I am not going to saturate the market with these cars. I am not able to travel around the world promoting it. I decided to offer the most exotic, high performance car i could dream up and this is what i have come up with.
Thank you guys for all the support. It is nice that even guys who wont run this car can appreciate what i am trying to accomplish. You are a good bunch of guys.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 02-10-2013, 04:41 AM   #329
protc3's Avatar
That is correct. Losi springs are way too soft. Borderline pen springs.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 02-10-2013, 02:26 PM   #330
protc3's Avatar
This week I am going to try to make the steering blocks, C hubs and steering spindles. That will be it for the front end, Then it is on to the pod. I cant wait to try this thing out.
Jason Breiner
BMI Racing
Team Associated
J Concepts
BMI Racing "Copperhead 12" discussion and support protc3 Electric On-Road 2609 01-08-2015 06:24 PM
BMI Racing "Copperhead 10" Support and Discussion protc3 Electric On-Road 315 08-11-2013 04:34 PM
ADRENALINE R/C Raceway rc action Florida Racing 5387 11-04-2012 07:20 AM
