Old 12-30-2012, 06:19 AM   #1
catawissarocket's Avatar
Default Team associated tc3 question/help
Not sure if im posting in the right section but anyways i 4 brand new team associated shocks and yesterday throughout the day while racing i found that 3 out of the 4 were leaking from the bottom of the shock body i assume.these are brand new and were built properly. is there a better rebuild kit out there or something that will correct this?
Bumps and jumps
catawissarocket is offline   Reply With Quote
Old 12-30-2012, 06:40 AM   #2
abailey21's Avatar
Trader Rating: 36 (100%+)
being the TC3 is a 10+ year old car, if you have a brand new one the rubber
o-rings are probably rotted from age
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 12-30-2012, 06:49 AM   #3
Im sorry, i was talking team associated shocks(blue ones)
Bumps and jumps
Old 12-30-2012, 07:22 AM   #4
Suspended
You don't have any problems here . The Ae shocks do leak from the top even when new. You'll need to get yokomo(#YS-8DMH bladders to solve the problem... Good luck....
bertrandsv87 is offline   Reply With Quote
Old 12-30-2012, 07:45 AM   #5
SteveM's Avatar
Trader Rating: 142 (100%+)
The FT TC3 shocks are great little units but do need to be built carefully. Make sure that all the O-rings are in good shape and use AE Green Slime when assembling the lowers. The upper caps tend to leak and that's pretty much par for the course. A simple fix is to replace the shocks with a set of Tamiya TRF shocks.
SteveM is offline   Reply With Quote
Old 12-30-2012, 07:58 AM   #6
Suspended
Trf shocks are the best but cost $55+.... The Yokomo #YS-8DMH bladders cost $4 , and will make the Ae shocks Work almost as good as the trf shocks. Also, when you build your shocks, you should not scratch the shock shaft at all . Do not hold it with bare plyers, and do not put the O rings through the threads but only through the piston side of the shaft (that will prevent tears). Also lube the shaft and O rings first before installation. Using green slime is definitely good.....
Old 12-30-2012, 08:02 AM   #7
Thanks alot guys, much appricated..
Bumps and jumps
Old 12-30-2012, 08:03 AM   #8
where can i get these bladders? any links? thanks, shawn..
Bumps and jumps
Old 12-30-2012, 08:21 AM   #9
Bikerbob's Avatar
Send a message via ICQ to Bikerbob Send a message via MSN to Bikerbob Send a message via Yahoo to Bikerbob
Try A-main hobbies, they are the official Yokomo source in North America, otherwise you can find them on ebay lots of times as well.
James
Bikerbob is offline   Reply With Quote
Old 12-30-2012, 08:27 AM   #10
Suspended
They are available at Amainhobbies right now...
Old 12-30-2012, 10:26 AM   #11
Thanks for the replys guys, i'll check them out..
Bumps and jumps
Old 01-03-2013, 02:26 PM   #12
Quick question, they are leaking from the bottom how will these help me?? figured i would ask before i order them..
Bumps and jumps
Old 01-03-2013, 02:41 PM   #13
Suspended
If They are leaking from the bottom, then relieving the pressure at the top with a bladder/foam system will make them stop leaking everywhere, provided that your bottom O rings are good , and your shock shaft is not scratched up....
Old 01-03-2013, 03:26 PM   #14
thankyou for the info..
Bumps and jumps
Team Associated TC4 Kenshin Electric On-Road 15354 11-29-2017 01:36 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 08:58 AM
Team Associated B44. Race, Tune and Modify Shadows Electric Off-Road 6171 08-09-2015 08:32 AM
