motor runs faster backwards
Hi all,
I just bought an old HPI RS4 mini (not micro). It included a Nosram Tomahawk esc,and a Nosram brushed Super Stock motor. I know the electronics are old, but they still work. The question I had is why would the motor run faster backwards then frontwards. It's kind of frustrating, because I know the motor goes faster than it's running right now, because it's better backwards. I've run across this with another car I have, but never knew why. I guess I could switch motor leads, but I was wondering why this would happen. Anyone know? Thanks for your help. |
Originally Posted by rody63
(Post 11608419)
Hi all,
Brushed motors only have 2 leads. Swapping them over will reverse the motor which wont work in the car. I know when i use to race 540 silver can, the motors were actually retarded from factory which meant they run faster in reverse. Without twisting the com, i don't think there is anything you can do about it ( unless the motor has adjustable timing that is )
Switching polarity, car may run backwards. remove the top of diffs and diff gears turn them 180degrees. This will turn correct the direction.
info
Ucan turn endbell 180 degrees.. and swap motor leads that should fix ur issue..dont u love when people answer with Wrong info cause they dont read the post..
Originally Posted by Geezatec
(Post 11608551)
(Post 11608419)
Hi all,
I just bought an old HPI RS4 mini (not micro). It included a Nosram Tomahawk esc,and a Nosram brushed Super Stock motor. I know the electronics are old, but they still work. The question I had is why would the motor run faster backwards then frontwards. It's kind of frustrating, because I know the motor goes faster than it's running right now, because it's better backwards. I've run across this with another car I have, but never knew why. I guess I could switch motor leads, but I was wondering why this would happen. Anyone know? Thanks for your help. I think this will help...Start by changing your throttle servo direction on the controller. You will most likely have to swap the motor leads around too. Cheers |
I would say the ESC has been calibrated backwards, and then the motor leads have been swapped over to get it to run the right way, so when you pull the throttle the ESC is going backwards.
Swap the motor leads round and then switch the servo reverse on the transmitter and it should run faster in forwards. You might need to recalibrate it to reset the end points. |
Originally Posted by terry.sc
(Post 11611031)
(Post 11620947)
Well, I ended up doing this, and it actually was faster, the only problem was that for some reason the car would stop responding, and stall. I could get it to go again by hitting reverse momentarily, and then going forward, but it kept cutting out. When I put things back the way the were before, it worked perfect, although slower.
(Post 11608419)
Hi all,
If all else fails you could buy a Mardave. The motor in them runs backwards to everything else.
(Post 11620947)
